I installed my HIDs today and ended up having to put wire in a relay for each headlight. Everything works fine EXCEPT that the message center constantly says "check right headlight" "check left headlight". I found that if i hit reset it goes away. So I thought my problem was solved. But NOOOO not that easy. After 10-15 minutes it came back on. So i have to hit reset each time it comes on. Is there a way to correct this or does it pretty much mean that my does not want HIDs. Could anyone help me out with my problem?
Mine sometimes comes on when it's cold. Sounds like the ballasts aren't getting their charge early enough.
