Hi.
Why suddenly the EASY ACCESS seat option is no longer working everytime I remove or insert my key in, the seat won't move back when the key is out and wont move forward when I put the key in. Everything is working manually... All positions.
Thanks.
Administrator
Hi.
Thanks.
Hi Mistral. Unfortunately, there is no way to accurately diagnose this blindly over the Internet.
I would recommend you try to reset the memory seat buttons to your desired positions again to see if that helps.
If it does not, you will need to have it diagnosed by your Ford Dealer.
Administrator
Thanks.
How do you RESET all the memory button if it can be done?
Hi Mistral. Just try to set the Easy Access Memory 1 and Memory 2 buttons again. As you did at some time after you purchased the car.
It is an attempt to set them to your desired positions, in case the memory was lost somehow.
