What would be a good way to upgrade to an 8 speaker system? Possibly tap into the rear door speakers? Run an AMP for the rear deck speakers?
The easiest way is not the best way. The easiest is to obviously tap into the rear speakers. This in turn doubles the load, and your now pushing 2 ohms with your stock HU. I don't think it will like high volumes for very long periods of time.
The best would be to power them off an amp. If you do so -- you will want to also power/upgrade your front speakers. The best sound stage should still come from the front. The best would be to also purchase a new rear deck cover -- with the grill covers built in.
If you search on here, several have tried adding these speakers. In the end, it wasn't worth it. If your planning on going "all-out", it may be worth it to add 6x9s in the rear -- and simply do not use the rear door speakers.
