Hello guys. 2012 sport with HID fogs and it’s always the driver side dogs that sometimes turns on. Passenger aide always works fine. Any one had any issues with fog ,off going out on the driver side all the time. The bulb is still good and swapped the bulbs and ballast. Around. Still does the same thing after awhile. Fuse looked fine.
Anyone with same issues ? Probably,t gonna swap to led fogs but leave his for my headlights
Thx in advance guys.
Hi xalex. Your 2012 Fusion Sport came equipped from the factory with H11 halogen foglight bulbs. Did you retrofit HID bulbs? If yes, that is probably your problem. Your best course of action would be to reinstall the proper H11 halogen bulbs.
If installing the proper halogen bulbs does not solve the problem, then there is probably a connector or wiring issue.
