Hello,
I have a 2008 Ford Fusion Se 2.3 with the 4f27e 4 speed transmission with about 145k miles on it. I recently replaced my all 6 of my solenoids because I was given code P0766 aka “solenoid d stuck open” instead of just one for preventative maintenance as well as tranny on gasket and new fluid. Took care of the car slamming into reverse and gave me back 4th gear after not being about to shift into it and rpm would ascend without a shift. But now, I have no lights on, car sounds good but delays shifting from 1st to 2nd. Cars rpm goes up to 3k-4.5k rpm when it should be shifting into second, and then all the other gears shift as should. Just hesitation from 1st to 2nd followed by a not too hard but different then usual shift. Any help?
A US based Fusion with the 4F27E? An 08 should have the FNR5 5 speed (which is based on the 4F27E and many parts are reused).
