These would only work on the 2.5L in the 2013, and wouldnt exceed the max hp rating of the transmission.
For other Duratecs, it also shouldnt be an issue. Max gains will probably be in the 15-20hp range.
Performance level - Stage 2T - Forced Induction - Designed specifically for turbo or supercharger applications. Low duration, high lift profile. Requires Crower spring kit #84170.
INT/EXH - Dur @ .050” Lift: 220°/220° RR: 1/1 Gross Lift: .400”/.400” LSA: 112° RPM: Idle to 8000 Redline: 8500
Discussion Starter · #5 · (Edited)
That just means its cam profile is designed for forced induction applications, but doesnt mean it would work on the FI engines like 2.3 MZR DISI or ecoboost. It would also require a spring kit.
This profile is the best for any NA build and would be appropriate for 99% of situations.
Performance level - Stage 1 - Street use with emphasis on bottom end and mid range power. Works with stock springs up to factory rev limiter.
INT/EXH - Dur @ .050” Lift: 220°/214° RR: 1/1 Gross Lift: .374”/.363” LSA: 114° RPM: Idle to 7000 Redline: 7500
Now, maybe we could get custom cams made for the ecoboost, but it would require tuning, which we currently dont have access to.
Crower offers cams for the Duratec and MZR i4 engines. They may even be able to make custom cams for the v6 duratecs.
They fit the 2.0, 2.3, and 2.5L i4 engines found in both Mazda and Ford vehicles. These will also probably not require tuning, but being able to do additional tuning could yield further benefits.
http://www.ebay.com/itm/Massive-Crower-Custom-Cams-Camshafts-MZR-Duratec-Fusion-Mazda-3-6-2-0-2-3-2-5-/261228927827?pt=Motors_Car_Truck_Parts_Accessories&fits=Year:2013|Make:Ford|Model:Fusion&hash=item3cd2751b53&vxp=mtr
I’ve got a 1.5L 2015 fusion SE, would these cams work the same? I’ve found some parts I’d like to put on mine but I’m unsure as to whether or not it makes a difference that my car is 1.5 instead of 2.0
Hi Pearly. No, they will not work for your 1.5L Fusion.
