21 - 29 of 29 Posts
I would love cooled seats ... but I live in Edmonton, Alberta ... and this year I think we're only going to have 12 days where it's not winter. :rofl:
Also, keep in mind, perforated for appearance, and for purposes of cooled seats are different types of perforations. Cooled seats usually use a smaller perforation, straight punched, all the way through the leather. Perforation for apperance is more of a pitting process, but does not go all the way through the leather typically.
Discussion starter · #23 ·
[quote author=Ferendon link=topic=187133.msg3955321#msg3955321 date=1299546717]
The leather in the Fusion Sport is perforated through the leather.
[quote author=bbf2530 link=topic=187133.msg3950457#msg3950457 date=1299100608]
"They use a Peltier device with a small fan to blow hot or cool air through the perforations. It's an electrical device that produces heat or cold depending on the polarity of the current."[/quote]So does this mean that if you already have heated seats that you can just reverse the polarity and have cooled seats? Now you've spiked my curiosity and I have to check the diagrams :p
Discussion starter · #25 ·
:popcorn: Please do.. Im still confused if its a completely separate unit in the Ford than in the Lincoln. :dunno:
I found it... :)
It looks like they use a mating similar to a heating pad. Seems to flip polarity via MS CAN (gray/org and violet/org).
The Electronic Manual Temperature Control (EMTC) system heats or cools the vehicle depending on the HVAC module — control panel selection.
Car needs Front Controls Interface Module (FCIM) (comes with Fusion and Milan with navigation and all MKZ)
The wiring diagram is identical for the Fusion/Milan with heated seats as compared to the MKZ. Same parts/wiring color codes/etc.
Only problem I see is where to put the (cooling) switch for the Fusion/Milan...
Discussion starter · #28 ·
Exactly where the buttons are in the Lincoln.. They are blank/fake buttons in the Fusion. (mine at least) They are right under the heated seat buttons.
Oh snap.... I was just about to say that I have a different dash but when I looked I saw those same spots are open for switches on mine...
I wonder if Ford is going to offer the cooled version for 2013? Those empty buttons are to perfect for anything else :)
21 - 29 of 29 Posts
