As the proud owner of a 2006 Ford Fusion SEL, I have one major complaint, that the yahoos at the local dealer don't seem to want to research for me. When I shut off the car for the night with the climate control in Auto, and go out the next morning and start it up, it wants to blow A/C full blast until the motor idles down and I drive for about 2 miles, at which point the Exterior temp display finally goes down to the correct temperature. It seems like it's stuck from the night before. This morning it was still reading 83 and the actual temp was 74. I could understand it if the motor was hot, but I'm talking about a stone cold motor. I figured what the hell this morning and tried the old Self-Test (Hold Off and Defrost then press Auto) It went through the test and did not return any fault codes. Any thoughts?? The service manager suggested turning it off the night before and turning it back on the next morning, which has no effect. Do I have a bad Exterior temp sensor, or do I have a bad interior temp sensor, or is the programming in this EATC just way more retarted than the Grand Marquis and Taurus SHO I've had in the past.
Any thoughts or suggestions would be greatly appreciated.
Thanks
Thanks
