Here is a list of OBD II Diagnostic Codes:
P0700 Transmission Control System (MIL Request)
P0703 Brake Switch B Input Circuit
P0704 Clutch Switch Input Circuit
P0705 Transmission Range Sensor Circuit (PRNDL Input) *
P0707 Transmission Range Sensor Circuit Low Input *
P0708 Transmission Range Sensor Circuit High Input *
P0712 Transmission Fluid Temperature Sensor Circuit Low Input ^
P0713 Transmission Fluid Temperature Sensor Circuit High Input ^
P0715 Turbine Shaft Speed Sensor Circuit *
P0717 Turbine Shaft Speed Sensor Circuit No Signal
P0718 Turbine Shaft Speed Sensor Circuit Intermittent ^
P0720 Output Shaft Speed Sensor Circuit *
P0721 Output Shaft Speed Sensor Circuit Range/Performance ^
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0731 Gear 1 Incorrect Ratio ^
P0732 Gear 2 Incorrect Ratio ^
P0733 Gear 3 Incorrect Ratio ^
P0734 Gear 4 Incorrect Ratio ^
P0735 Gear 5 Incorrect Ratio ^
P0741 Torque Converter Clutch Solenoid Circuit Performance Or Stuck Off ^
P0743 Torque Converter Clutch Solenoid Circuit Electrical *
P0745 Pressure Control Solenoid A *
P0746 Pressure Control Solenoid A Performance or Stuck Off *
P0750 Shift Solenoid A *
P0751 Shift Solenoid A Performance or Stuck Off *
P0755 Shift Solenoid B *
P0756 Shift Solenoid B Performance or Stuck Off *
P0760 Shift Solenoid C *
P0761 Shift Solenoid C Performance or Stuck Off *
P0765 Shift Solenoid D *
P0766 Shift Solenoid D Performance or Stuck Off *
P0770 Shift Solenoid E *
P0771 Shift Solenoid E Performance or Stuck Off *
P0775 Pressure Control Solenoid B *
P0779 Pressure Control Solenoid B Intermittent
P0781 1-2 Shift ^
P0782 2-3 Shift ^
P0783 3-4 Shift ^
P0791 Intermediate Shaft Speed Sensor Circuit
P0794 Intermediate Shaft Speed Sensor Circuit Intermittent ^
P0795 Pressure Control Solenoid C *
P0796 Pressure Control Solenoid C Performance or Stuck Off *
P0797 Pressure Control Solenoid C Stuck On *
P0799 Pressure Control Solenoid C Intermittent
P0812 Reverse Input Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0818 Driveline Disconnect Switch Input Circuit
P0840 Transmission Fluid Pressure Sensor/Switch A Circuit
P0844 Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
P1000 OBD Systems Readiness Test Not Complete
P1001 KOER Not Able to Complete, KOER Aborted
P1100 Mass Air Flow Sensor Circuit Intermittent
P1101 Mass Air Flow Sensor Out Of Self Test Range
P1109 Intake Air Temperature B Circuit Intermittent
P1112 Intake Air Temperature Circuit Intermittent
P1114 Intake Air Temperature B Circuit Low Input (Super/Turbo Charged engines) *
P1115 Intake Air Temperature B Circuit High Input (Super/Turbo Charged engines) *
P1116 Engine Coolant Temperature Sensor Out Of Self Test Range
P1117 Engine Coolant Temperature Sensor Circuit Intermittent
P1120 Throttle Position Sensor A Out Of Range Low (Ratch too low) *
P1121 Throttle Position Sensor A Inconsistent With Mass Air Flow Sensor *
P1122 Pedal Position Sensor A Circuit Low Input
P1123 Pedal Position Sensor A Circuit High Input
P1124 Throttle Position Sensor A Out Of Self Test Range
P1125 Throttle Position Sensor A Intermittent
P1127 Exhaust Not Warm, Downstream O2 Sensor Not Tested
P1128 Upstream HO2S Sensors Swapped
P1129 Downstream HO2S Sensors Swapped
P1130 Lack Of HO2S11 Switches - Fuel Trim At Limit *
P1131 Lack Of HO2S11 Switches - Sensor Indicates Lean *
P1132 Lack Of HO2S11 Switches - Sensor Indicates Rich *
P1133 Bank 1 Fuel Control Shifted Lean (FAOSC) [ *]
P1134 Bank 1 Fuel Control Shifted Rich (FAOSC) [ *]
P1135 Pedal Position Sensor A Circuit Intermittent
P1137 Lack Of HO2S12 Switches - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switches - Sensor Indicates Rich
P1150 Lack Of HO2S21 Switches - Fuel Trim At Limit *
P1151 Lack Of HO2S21 Switches - Sensor Indicates Lean *
P1152 Lack Of HO2S21 Switches - Sensor Indicates Rich *
P1153 Bank 2 Fuel Control Shifted Lean (FAOSC) [ *]
P1154 Bank 2 Fuel Control Shifted Rich (FAOSC) [ *]
P1155 Alternative Fuel Control Module Has Activated the MIL
P1157 Lack Of HO2S22 Switches - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switches - Sensor Indicates Rich
P1168 Fuel Rail Pressure Sensor In Range But Low
P1169 Fuel Rail Pressure Sensor In Range But High
P1180 Fuel Delivery System - Low
P1181 Fuel Delivery System - High
P1183 Engine Oil Temperature Sensor Circuit *
P1184 Engine Oil Temperature Sensor Out Of Self Test Range *
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1220 Series Throttle Control System
P1221 Traction Control System [ ] [ ] [ ]
P1222 Pedal Position Sensor B Circuit Low Input
P1222 Traction Control Output Circuit [ ]
P1223 Pedal Position Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1227 Wastegate Failed Closed (Over pressure) *
P1228 Wastegate Failed Open (Under pressure) *
P1229 Charge Air Cooler Pump Driver *
P1230 Fuel Pump Low Speed Malfunction (VLCM)
P1231 Fuel Pump Secondary Circuit Low, High Speed (VLCM)
P1232 Fuel Pump Speed Primary Circuit (Two speed fuel pump)
P1233 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module) *
P1234 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module)
P1235 Fuel Pump Control out Of Range (Fuel Pump Driver Module/VLCM) *
P1236 Fuel Pump Control Out Of Range (Fuel Pump Driver Module)
P1237 Fuel Pump Secondary Circuit (Fuel Pump Driver Module) *
P1238 Fuel Pump Secondary Circuit (Fuel Pump Driver Module)
P1239 Speed Fuel Pump Positive Feed
P1243 Second Fuel Pump Fault or Ground Fault *
P1244 Alternator Load High Input
P1245 Alternator Load Low Input
P1246 Alternator Load Input
P1260 Theft Detected, Vehicle Immobilized
P1270 Engine RPM or Vehicle Speed Limiter Reached
P1285 Cylinder Head Overtemperature Condition
P1286 Fuel Pulsewidth In Range But Lower Than Expected
P1287 Fuel Pulsewidth In Range But Higher Than Expected
P1288 Cylinder Head Temperature Sensor Out Of Self Test Range
P1289 Cylinder Head Temperature Sensor Circuit High Input
P1290 Cylinder Head Temperature Sensor Circuit Low Input
P1299 Cylinder Head Overtemperature Protection Active *
P1309 Misfire Monitor AICE Chip Fault, Misfire Monitor Disabled *
P1310 Ionization Misfire Detection Module Fault *
P1311 Ionization Misfire Detection Module Communication Fault *
P1340 Camshaft Position Sensor B Circuit *
P1351 Ignition Diagnostic Monitor Input Circuit *
P1352 Ignition Coil A Primary Circuit *
P1353 Ignition Coil B Primary Circuit *
P1354 Ignition Coil C Primary Circuit *
P1355 Ignition Coil D Primary Circuit *
P1356 Ignition Diagnostic Monitor Indicates Engine Not Turning *
P1357 Ignition Diagnostic Monitor Pulsewidth Not Defined *
P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range (no CPU OK)
P1359 Spark Output Circuit *
P1360 Ignition Coil A Secondary Circuit [ ]
P1361 Ignition Coil B Secondary Circuit [ ]
P1362 Ignition Coil C Secondary Circuit [ ]
P1363 Ignition Coil D Secondary Circuit [ ]
P1364 Ignition Coil Primary Circuit *
P1365 Ignition Coil Secondary Circuit [ ]
P1366 Ignition Spare [ ]
P1367 Ignition Spare [ ]
P1368 Ignition Spare [ ]
P1369 Engine Temperature Light Circuit
P1380 Camshaft Position Actuator Circuit (Bank 1) *
P1381 Camshaft Position Timing Over Advanced (Bank 1) *
P1383 Camshaft Position Timing Over Retarded (Bank 1) *
P1385 Camshaft Position Actuator Circuit (Bank 2) *
P1386 Camshaft Position Timing Over Advanced (Bank 2) *
P1388 Camshaft Position Timing Over Retarded (Bank 2) *
P1390 Octane Adjust Service Pin In Use/Circuit Open
P1400 Differential Pressure Feedback EGR Circuit Low Input *
P1401 Differential Pressure Feedback EGR Circuit High Input *
P1402 Exhaust Gas Recirculation Metering Orifice Restricted [ *]
P1403 Differential Pressure Feedback Sensor Hoses Reversed *
P1404 EGR Temperature Sensor Circuit *
P1405 Differential Pressure Feedback Sensor Upstream Hose Off Or Plugged *
P1406 Differential Pressure Feedback Sensor Downstream Hose Off Or Plugged *
P1407 Exhaust Gas Recirculation No Flow Detected [ *]
P1408 Exhaust Gas Recirculation Flow Out Of Self Test Range
P1409 EGR Vacuum Regulator Solenoid Circuit *
P1410 Auxiliary Air Cleaner Inlet Control Circuit
P1411 Secondary Air Injection Incorrect Downstream Flow Detected *
P1413 Secondary Air Injection Monitor Circuit Low Input *
P1414 Secondary Air Injection Monitor Circuit High Input *
P1431 Misfire Monitor Disabled, unable to learn trigger wheel profile *
P1442 Evaporative Emission Control System Control Leak Detected
P1443 Evaporative Emission Control System Control Valve *
P1444 Purge Flow Sensor Circuit Low Input *
P1445 Purge Flow Sensor Circuit High Input *
P1450 Unable to Bleed Up Fuel Tank Vacuum *
P1451 Evaporative Emission Control System Vent Control Circuit *
P1452 Unable to Bleed Up Fuel Tank Vacuum
P1455 Evaporative Emission Control System Control Leak Detected (gross leak/no flow)
P1457 Unable To Pull Fuel Tank Vacuum
P1460 Wide Open Throttle A/C Cutout Circuit
P1461 A/C Pressure Sensor Circuit High Input
P1462 A/C Pressure Sensor Circuit Low Input
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out Of Self Test Range
P1465 A/C Relay Circuit
P1466 A/C Refrigerant Temperature Sensor Circuit
P1469 Rapid A/C Cycling
P1473 Fan Circuit Open (VLCM)
P1474 Fan Control Primary Circuit
P1479 High Fan Control Primary Circuit
P1480 Fan Secondary Low With Low Fan On [ ] [ ]
P1481 Fan Secondary Low With High Fan On [ ] [ ]
P1482 SCP [ ]
P1483 Brake Pedal Input Short To Battery
P1483 Fan Circuit Shorted To Ground (VLCM)
P1484 Fan Driver Circuit Open To Power Ground (VLCM)
P1485 Brake Pedal Input Short To Battery
P1500 Vehicle Speed Sensor
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent ^
P1504 Idle Air Control Circuit *
P1505 Idle Air Control System At Adaptive Clip *
P1506 Idle Air Control Overspeed Error *
P1507 Idle Air Control Underspeed Error *
P1512 Intake Manifold Runner Control Stuck Closed (Bank 1)
P1513 Intake Manifold Runner Control Stuck Closed (Bank 2)
P1516 Intake Manifold Runner Control Input Error (Bank 1) *
P1517 Intake Manifold Runner Control Input Error (Bank 2) *
P1518 Intake Manifold Runner Control Stuck Open (Bank 1) *
P1519 Intake Manifold Runner Control Stuck Closed (Bank 2)
P1520 Intake Manifold Runner Control Control Circuit *
P1530 A/C Clutch Circuit Open (VLCM)
P1532 Intake Manifold Communication Control Control Circuit (Bank 2)
P1533 Air Assisted Injector Circuit *
P1534 Restraint Deployment Indicator Circuit
P1537 Intake Manifold Runner Control Stuck Open (Bank 1) *
P1538 Intake Manifold Runner Control Stuck Open (Bank 2) *
P1539 A/C Clutch Circuit Overcurrent/Short (VLCM)
P1549 Intake Manifold Communication Control Control Circuit (Bank 1)
P1550 Power Steering Pressure Sensor Out Of Self Test Range
P1565 Speed Control Command Switch Out Of Range High
P1566 Speed Control Command Switch Out Of Range Low
P1567 Speed Control Output Circuit
P1568 Speed Control Unable to Hold Speed
P1572 Brake Pedal Switch Circuit
P1573 Throttle Position Not Available *
P1574 Throttle Position Sensor Outputs Disagree
P1575 Pedal Position Out Of Self Test Range
P1576 Pedal Position Not Available *
P1577 Pedal Position Sensor Outputs Disagree
P1578 ETC Power Less Than Demand [ *]
P1579 ETC In Power Limiting Mode [ *]
P1580 Electronic Throttle Monitor PCM Override *
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disablement
P1584 Throttle Control Detected ETB Malfunction
P1585 Throttle Control Malfunction *
P1586 Electronic Throttle to PCM Communication Error *
P1587 Throttle Control Modulated Command Malfunction *
P1588 Throttle Control Detected Loss Of Return Spring
P1589 Throttle Control Unable To Control To Desired Throttle Angle *
P1605 Keep Alive Memory Test Failure [ ]
P1610 SBDS Interactive
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1625 Fan Driver Circuit Open to Power B+ (VLCM)
P1626 A/C Circuit Open to Power B+ (VLCM)
P1633 Keep Alive Power Voltage Too Low *
P1635 Tire/Axle Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error *
P1639 Vehicle ID Block Corrupted, Not Programmed
P1640 Powertrain DTCs Available In Another Control Module (Ref. PID 0946) *
P1641 Fuel Pump Primary Circuit [ ] [ ] [ ]
P1642 CAN Link Circuit *
P1642 Fuel Pump Monitor Circuit High Input [DTC will be deleted on next version] [ ] [ ]
P1643 CAN Link ECM/TCM Circuit/Network *
P1643 Fuel Pump Monitor Circuit Low Input [DTC will be deleted on next version] [ ] [ ] [ ]
P1644 Fuel Pump Speed Control Circuit [ ]
P1650 Power Steering Pressure Switch Out Of Self Test Range
P1651 Power Steering Pressure Switch Input
P1656 CAN Link PCM/PCM Circuit/Network *
P1657 CAN Link Chip Malfunction *
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 Transmission Range Sensor Circuit Intermittent
P1703 Brake Switch Out Of Self Test Range
P1704 Transmission Range Circuit Not Indicating Park/Neutral During Self Test
P1705 Transmission Range Circuit Not Indicating Park/Neutral During Self Test
P1709 Park Neutral Position Switch Out Of Self Test Range
P1711 Transmission Fluid Temperature Sensor Out Of Self Test Range
P1712 Transmission Torque Reduction Request Signal
P1713 Transmission Fluid Temperature Sensor In Range Failure (< 50 deg F) ^
P1714 Shift Solenoid A Inductive Signature *
P1715 Shift Solenoid B Inductive Signature *
P1716 Shift Solenoid C Inductive Signature *
P1717 Shift Solenoid D Inductive Signature *
P1718 Transmission Fluid Temperature Sensor In Range Failure (> 250 deg F) ^
P1727 Coast Clutch Solenoid Inductive Signature ^
P1728 Transmission Slip
P1729 4x4L Switch
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1740 Torque Converter Clutch Solenoid Inductive Signature *
P1741 Torque Converter Clutch Solenoid Control Error
P1742 Torque Converter Clutch Solenoid Circuit Failed On *
P1743 Torque Converter Clutch Solenoid Circuit Failed On ^
P1744 Torque Converter Clutch Solenoid Circuit Performance *
P1746 Pressure Control Solenoid A Open Circuit ^
P1747 Pressure Control Solenoid A Short Circuit *
P1749 Pressure Control Solenoid A Failed Low
P1751 Shift Solenoid A Performance ^
P1754 Coast Clutch Solenoid Circuit ^
P1756 Shift Solenoid B Performance ^
P1760 Pressure Control Solenoid A Short Circuit Intermittent ^
P1761 Shift Solenoid C Performance ^
P1762 Overdrive Band Failed Off *
P1766 Shift Solenoid D Performance ^
P1767 Torque Converter Clutch Circuit ^
P1768 Performance/Normal/Winter Mode Input
P1770 Clutch Solenoid Circuit
P1780 Transmission Control Switch (O/D Cancel) Circuit Out Of Self Test Range
P1781 4X4L Circuit Out Of Self Test Range
P1782 Performance/Economy Switch Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition ^
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid B Open Circuit *
P1789 Pressure Control Solenoid B Short Circuit *
P1795 Inconsistent CAN Level *
P1804 4-Wheel Drive High Indicator Circuit Open or Shorted To Ground
P1806 4-Wheel Drive High Indicator Short To Battery
P1808 4-Wheel Drive Low Indicator Circuit Open or Short To Ground
P1810 4-Wheel Drive Low Indicator Short To Battery
P1812 4-Wheel Drive Mode Select Switch Circuit Open
P1815 4-Wheel Drive Mode Select Switch Circuit Short To Ground
P1819 Neutral Safety Switch Input Short To Ground
P1820 Transfer Case LO To HI Shift Relay Circuit Open Or Short To Ground
P1822 Transfer Case LO To HI Shift Relay Coil Short To Battery
P1824 4-Wheel Drive Electric Clutch Relay Open Or Short To Ground
P1826 4-Wheel Drive Electric Clutch Relay Short To Battery
P1828 Transfer Case HI To LO Shift Relay Coil Circuit Open Or Short To Ground
P1830 Transfer Case HI To LO Shift Relay Coil Circuit Short To Battery
P1832 Transfer Case 4-Wheel Drive Solenoid Circuit Open or Short To Ground
P1834 Transfer Case 4-Wheel Drive Solenoid Circuit Short To Battery
P1838 No Shift Motor Movement Detected
P1846 Transfer Case Contact Plate 'A' Circuit Open
P1850 Transfer Case Contact Plate 'B' Circuit Open
P1854 Transfer Case Contact Plate 'C' Circuit Open
P1858 Transfer Case Contact Plate 'D' Circuit Open
P1866 Transfer Case Cannot Be Shifted
P1867 Transfer Case Contact Plate General Circuit Failure
P1876 Transfer Case 2-Wheel Drive Solenoid Circuit Open Or Short To Ground
P1877 Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1881 Engine Coolant Level Switch Circuit
P1882 Engine Coolant Level Switch Circuit Short To Ground
P1883 Engine Coolant Level Switch Circuit
P1884 Engine Coolant Level Lamp Circuit Short To Ground
P1891 Transfer Case Contact Plate Ground Return Open Circuit
P1900 Output Shaft Speed Sensor Circuit Intermittent
P1901 Turbine Shaft Speed Sensor Circuit Intermittent
U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch Sense Input
U1039 SCP (J1850) Invalid or Missing Data for Vehicle Speed *
U1051 SCP (J1850) Invalid or Missing Data for Brake Input
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant Fan Status
U1075 SCP (J1850) Invalid or Missing Data for Engine Oil Temperature
U1131 SCP (J1850) Invalid or Missing Data for Fuel Pump Status
U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1451 SCP (J1850) Invalid or Missing Data From Anti-Theft Module, Vehicle Immobilized
U2015 SCP (J1850) Invalid or Missing Data From NGV Module
More codes:
0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P0120 ETS MainThrottle Position Sensor Malfunction (Hyundai)
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0128 Range/Performance Problem In Thermostat(Acura)
P0128 ECT Below Thermostat Regulating Temperature(GM)
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0220 ETS Throttle Position Sensor Property Malfunction (Hyundai)
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
And more:
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0339 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermitten
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 EVAP Leak Monitor Small Leak Detected (CHRYSLER)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 CRUISE CONTROL ON SIGNAL MALFUNCTION
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0577 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) ErroR
P0606 PCM Processor Fault Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0645 A/C Clutch Relay Circuit
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
In addition to the above, here are some Ford specific/Ford "only" Codes:
P1000 OBD-II Monitor Testing Incomplete
P1001 KOER Test Cannot Be Completed
P1039 Vehicle Speed Signal Missing or Improper
P1051 Brake Switch Signal Missing or Improper
P1100 Mass Air Flow Sensor Intermittent
P1101 Mass Air Flow Sensor out of Self-Test Range
P1112 Intake Air Temperature Sensor Intermittent
P1116 Engine Coolant Temperature Sensor is out of Self-Test Range
P1117 Engine Coolant Temperature Sensor Intermittent
P1120 Throttle Position Sensor out of range
P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
P1124 Throttle Position Sensor out of Self-Test Range
P1125 Throttle Position Sensor Intermittent
P1127 Heated Oxygen Sensor Heater not on During KOER Test
P1128 Heated Oxygen Sensor Signals reversed
P1129 Heated Oxygen Sensor Signals reversed
P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1135 Ignition Switch Signal Missing or Improper
P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1220 Series Throttle Control fault
P1224 Throttle Position Sensor B out of Self-Test Range
P1230 Open Power to Fuel Pump circuit
P1231 High Speed Fuel Pump Relay activated
P1232 Low Speed Fuel Pump Primary circuit failure
P1233 Fuel Pump Driver Module off-line
P1234 Fuel Pump Driver Module off-line
P1235 Fuel Pump Control out of range
P1236 Fuel Pump Control out of range
P1237 Fuel Pump Secondary circuit fault
P1238 Fuel Pump Secondary circuit fault
P1250 Lack of Power to FPRC Solenoid
P1260 Theft Detected - Engine Disabled
P1288 Cylinder Head Temperature Sensor out of Self-Test Range
P1289 Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range
P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309 Misfire Detection Monitor not enabled
P1351 Ignition Diagnostic Monitor circuit Input fault
P1352 Ignition Coil A - Primary circuit fault
P1353 Ignition Coil B - Primary circuit fault
P1354 Ignition Coil C - Primary circuit fault
P1355 Ignition Coil D - Primary circuit fault
P1356 Loss of Ignition Diagnostic Module Input to PCM
P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range
P1359 Spark Output circuit fault
P1364 Ignition Coil Primary circuit fault
P1380 VCT Solenoid Valve circuit Short or Open
P1381 Cam Timing Advance is excessive
P1383 Cam Timing Advance is excessive
P1390 Octane Adjust out of Self-Test Range
P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage
P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405 Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
P1407 EGR No Flow Detected
P1408 EGR Flow out of Self-Test Range
P1409? EGR Vacuum Regulator circuit malfunction
P1409? Electronic Vacuum Regulator Control circuit fault
P1410 EGR Barometric Pressure Sensor VREF Voltage
P1411 Secondary Air is not being diverted
P1413 Secondary Air Injection System Monitor circuit Low Voltage
P1414 Secondary Air Injection System Monitor circuit High Voltage
P1442 Secondary Air Injection System Monitor circuit High Voltage
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1444 Purge Flow Sensor circuit Input Low
P1445 Purge Flow Sensor circuit Input High
P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1455 Substantial Leak or Blockage in Evaporative Emission Control System
P1460 Wide Open Throttle Air Conditioning Cutoff circuit malfunction
P1461 Air Conditioning Pressure Sensor circuit Low Input
P1462 Air Conditioning Pressure Sensor circuit high Input
P1463 Air Conditioning Pressure Sensor Insufficient Pressure change
P1464 ACCS to PCM High During Self-Test
P1469 Low Air Conditioning Cycling Period
P1473 Fan Secondary High with Fans Off
P1474 Low Fan Control Primary circuit
P1479 High Fan Control Primary circuit
P1480 Fan Secondary Low with Low Fans On
P1481 Fan Secondary Low with High Fans On
P1483 Power to Cooling Fan Exceeded Normal Draw
P1484 Variable Load Control Module Pin 1 Open
P1500 Vehicle Speed Sensor Intermittent
P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure
P1502 Invalid or Missing Vehicle Speed Message or Brake Data
P1504 Intake Air Control circuit malfunction
P1505 Idle Air Control System at Adaptive Clip
P1506 Idle Air Control Over Speed Error
P1507 Idle Air Control Under Speed Error
P1518 Intake Manifold Runner Control fault - Stuck Open
P1519? Intake Manifold Runner Control Stuck Open
P1520? Intake Manifold Runner Control circuit fault
P1519? Intake Manifold Runner Control fault - Stuck Closed
P1520? Intake Manifold Runner Control fault
P1530 Open or Short to A/C Compressor Clutch circuit
P1539 Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw
P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection
P1550 Power Steering Pressure Sensor out of Self-Test Range
P1605 PCM Keep Alive Memory Test Error
P1625 Voltage to Vehicle Load Control Module Fan circuit not detected
P1626 Voltage to Vehicle Load Control Module circuit not detected
P1650 Power Steering Pressure Switch out of Self-Test Range
P1651 Power Steering Pressure Switch Input fault
P1700 Transmission system problems
P1702 Transmission system problems
P1703 Brake On/Off Switch out of Self-Test Range
P1704 Transmission system problems
P1705 Manual Lever Position Sensor out of Self-Test Range
P1709 Park or Neutral Position Switch out of Self-Test Range
P1710 Transmission system problems
P1711 Transmission Fluid Temperature Sensor out of Self-Test Range
P1713
thru
P172 Transmission system problems
P1729 4x4 Low Switch Error
P1740 Transmission system problems
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Faulty
P1743 Torque Converter Clutch Solenoid Faulty
P1744 Torque Converter Clutch System Stuck in Off Position
P1745 Transmission system problems
P1746 Electronic Pressure Control Solenoid - Open circuit
P1747 Electronic Pressure Control Solenoid - Short circuit
P1749 Electronic Pressure Control Solenoid Failed Low
P1751 Shift Solenoid No. 1 Performance
P1754 Coast Clutch Solenoid circuit malfunction
P1756 Shift Solenoid No. 2 Performance
P1760 Transmission system problems
P1761 Shift Solenoid No. 3 Performance
P1762 Transmission system problems
P1767 Transmission system problems
P1780 Transmission Control Switch circuit is out of Self-Test Range
P1783 Transmission Over-Temperature Condition
P1784 Transmission system problems
P1785 Transmission system problems
P1786 Transmission system problems
P1787 Transmission system problems
P1788 Transmission system problems
P1789 Transmission system problems
P1900 Transmission system problems
