does changing the exaust void warranty??
It's only if the problem was caused by the changing of said parts. If you change your exhaust and your headlight falls out -- it's still covered.
That is true. The dealership would need to prove the exhaust caused the problem. But then that would only cause issues with the warranty on that exact issue. Adding an exhaust would not void your warranty flat out.
