Does any one have the instruction or can talk me through the front bumper/fascia removal? I tried twice this weekend but could not figure out what was holding the bumper to the car. I am trying to remove the grill so I can try out painting it.
I removed the following hardware;
7mm bolts (dozen or so) along the bottom of the bumper
The 6 panel fastener (3 per side) in the wheel well,
The two 10mm bolts and two panel fasteners on the top part of the bumper by the radiator support
The two screws that hold the corner of the marker light to the fender
it seems to still be attached around the center of the bumper between the upper and lower grill and just under the head lights but I have be able to locate anything else to remove.
Any Ideas or maybe any instructions? Thanks in advance
I have figured out where the bumper was hanging up on. There is a series of little plastic clip the run from the coner of the head light and marker light. I just need to pop the clips with a small screwdriver and the bump finally came off. After that everything went pretty well.
