1 - 12 of 12 Posts
For those with rims with a lot of space like mine, what do you do for the buildup of brake dust on the inner portion of the rims? I have seen cars with rims clean on the outside, but black on the inside. That will bother me. I am guessing I will have to stick my hand back there with a towel and and wash it.
Its a labor of love, Ceace. Just suck it up and put some elbow grease into it. :D
Yeah, my hand can fit between the spaces in the rims, so that is what I will do maybe every 3 washings. I just may have to move the car forward a foot about three times to get the entire radius of the rim. It is well worth it.
I would suggest washing it everytime if possible, otherwise the build up will require more time to clean. Your other option is to just power wash it out whenever you do a tire rotation. I guess you will be the best judge of how much build up you can afford before it starts looking really bad.
Take some pics for us!
You can go to dogpile.com and search "brake dust shield", There's a bunch of different kits depending on size and how you want to mount them, using caliper bolts, inside of rim, etc... The ones I saw aren't exactly made for looks, but only checked 1 or 2 brands. Keep me posted if you find anything.
Sure thing, Kev. More than likely though, I may just wash the inside of them with every detail, or like WIFL suggested, get better brake pads.
What brake dust? Compared to my old Contour this car has no brake dust to speak of. I love it. With the Contour, the wheels were filthy after 10 miles.
[quote author=Cueball link=topic=84344.msg1591681#msg1591681 date=1185561390]
The brake dust on the inside of my rims. :slap: The kind that was on your Contour. :slap: :wiggle:
[quote author=Ceace link=topic=84344.msg1587804#msg1587804 date=1185458897]
Hi Ceace. :wavey: Yes, we are all going to get a noticeable build up of brake dust. All we can do is clean it when it gets too hard to take. Personally, I just get as much as I can from the outside, as the rest is really not noticeable on the inside of the wheel.
On the plus side, I do notice that the build up is visibly less on our MKZ than it is on our Cougar, or any of our previous cars.
However, I would advise staying away from the brake dust shields you see advertised. Many of them have a tendency to cut down the air flow to your brakes, leading to higher brake temperatures, and possible problems. This is a warning I have seen many times, from many expert sources. Just thought I would play it safe, and pass it on.
Good luck! :cheers:
Good point, I think they look crappy too. I just wash mine the best I can from the outside and going to clean the hell out of them whenever I rotate the tires. (every 2 nd oil change.)
1 - 12 of 12 Posts
