21 - 23 of 23 Posts
Discussion Starter #21
[quote author=Opusnbill7 link=topic=210656.msg4240524#msg4240524 date=1339986676]
I ordered a replacement rear-view mirror from echomaster with the monitor in it (and then a camera too). Very nice and adds the one thing the Fusion SE doesn't have, but should...an outside temp display. :) It was a wired system so that was a little more work, but very happy with it and highly recommend their products.
Cool! That sounds awesome. I was thinking about a mirror like that too, but I like the OEM mirror, because it autodims and I really like that feature. Could you post some pictures of how it looks like installed? I guess it is bigger than the original one.
Here's the mirror installed. The video shows up on the left side, and the compass and outside temperature are on the upper right. It's hard-wired, so it only comes on when the brake lights go on. I also included a picture of the camera. I picked the one that looked most like the OEM camera and as you can see it blends in pretty nice (unless you're 6 in away :) ). It's mounted in between the plate lights, just like the OEM. Screw holes even lined up. :)
https://plus.google.com/photos/117580379998038466604/albums/5755568003568604129/5755568002751355778
https://plus.google.com/photos/117580379998038466604/albums/5755568003568604129/5755568025256267298
The mirror is a little bigger than stock, but I'd say only maybe 10% or so.
Finally got it working.
I had a PAC addon already wired in and hooked up to the reverse lead, but it didn't work. So I spliced into the reverse wire in the bundle in the drivers door sill. It was green/white wire, one of many.
What model/year was this on? I have a 2010 Fusion SE and need to find the reverse wire. Any ideas on the location and color? I’m not having any luck finding a picture or wiring diagram behind the kick panel.
21 - 23 of 23 Posts
