Yeah, my wife and I tinted our vehicles. I haven't done my Fusion yet. It is pretty easy, but you have to be patient because it takes time. You cut out a piece of film slightly larger than the window. Use tape to hold it in place and cut out the shape of the window slightly larger. Then you follow the instructions in the box to adhere it to the window. After that, you can cut off the access around the edges of the window so it can look like it is original. The time spent comes with using the rubber to press out all the air bubbles. You will get air bubbles, so be prepared for that. After you are done, just leave your car in the sun or turn on your heater in your car for...I leave it on for about 20 min. And that's it, man. Will take some hours to do to get it done right though.
