41 - 60 of 71 Posts
I found for the most part I could not go to home depot, lowes, walmart... their policies all were to not cut things they dont sell, that way if they break it they arent at fault... of course you may find someone who doesnt care or doesnt know about the policy.
Anyways I went to my ford dealership's part counter and had them cut it for like 8 bucks. They tried to scare the crap outa me about the chip could overload shit in the car if it wasnt right and cost hundreds to repair.... but thats why I ordered from someone with thousands of positive feedbacks.
i had mine cut for ~$5 at a local locksmith. the actual key part wiggles a little bit and feels a little flimsy but it hasnt broken or gotten any worse in the months that ive had it. it also has a slightly shorter range then the stock key, but other then that it works great.
So I brought my key to Canadian Tire and they told me the key wouldn't fit in the cutting machine. I went to a lock smith (All Lock Rescue) and they had no problem doing it. $5.00. The guy who cut my key also told me that if I had problems programming it to let him know. He was really cool.
Programming was interesting. To program the key to the ignition I had to:
1) use the first original key, put it in the ignition and turn it to position 3 and wait 3-10 seconds (check the manual for positions)
2) remove the key and wait 3-10 seconds
3) use the second original key, put it in the ignition and turn it to position 3 and wait 3-10 seconds
4) remove the key and wait 3-10 seconds
5) use the third (switchblade) key, put it in the ignition and turn it to position 3 and wait 6-20 seconds
After the programming remove the key. I opened the door to complete shut the car down. I then used the new key and put it in the ignition and turned it to position 3, waited and watched the security light to make sure it went off. If it turns off the ignition has accepted the key.
At this point I thought the buttons on the remote would work. But they didn't. I was confused and tried the above steps again and again and the buttons still didn't work. I was pissed and thought I had bought a crappy eBay knockoff that wasn't gonna work.
I went back into the store and told the guy that I couldn't get the buttons to work. He came out to my car and showed me what I had to do. Here are the steps:
1) Place one of the original key in the ignition and cycle it from position 1 to position 3 and back to position 1. Do this 8 times. (1-3-1 : 1-3-1 : 1-3-1 : 1-3-1 : 1-3-1 : 1-3-1 : 1-3-1 : 1-3-1)
2) After the cycling the locks will cycle (lock and unlock)
3) Once the locks cycle use the new remote and click 'lock'.
If this programming works the locks should lock with the new remote. Try all the buttons to make sure they all work and you're all done.
Enjoy your new remote.
I'm very happy. The quality seems to be very good. There is slight play between the key and the housing but nothing unusual. I feel if it was any tighter it would be to stiff. When you close the key and the key gets close to the housing there is a nice (satisfying) spring action pulling the key and keeping it closed.
The only downfall I found is the button to release the key is quite large and has no protection around it. It has already flipped open in my pocket by itself. I've had it in my pocket for two days now and only the once is not too bad to me. I'm not worried about that ... YET!
I would strongly recommend this as an alternative key. It's always recommended to have a third key so if you happen to lose one you don't have to pay a dealership to program it and overcharge you for it.
The one I ordered came with some fairly straight forward directions... but i did miss my timing on them or lost count or something along the way... i had to do atleast one of the processes more then once.
I do like your Ford emblem better then mine... mine is not ford blue, which bugs me that its close but not right :lol: and the height to length ratio is wrong.
Also just now i was looking at my logo to compare it to your pic... I had to twist that sucker back into alignment... didnt realize it could rotate.
Ive only had it for a month... its still solid, no wiggles, its not fading or getting beat up... still pretty new though, need some more time to see how its gonna really last.
[quote author=DreadX link=topic=201876.msg4239521#msg4239521 date=1339612965]
BTW ... thanks to ARFusion for finding the proper key for the 2010+ Fusions.
Go ahead and order yours .... you won't be disappointed!!
Where did you order it from?
Got my key today. I need to cut it and program now.
Got it programed.
Just need to make sure when going from 1-2-3 and 3-2-1 to do it quick. Not pause in between for like a second. I thought you had to pause for a second and then go back, so it wasn't working at the beginning. Then I just did it quick and the horn went off letting me know it was done. With no mistake it should take like 5 minutes.
41 - 60 of 71 Posts
