Does anyone have the actual numbers to set the suspension at? Ie camber (recommendations), toe, caster, etc for both the front and rear?
I believe that I have them at home. I will try to post them tommorrow. I am out of town right now.
Front
caster.........LH ( 4.0 +/- 1 Degree ) RH ( 4.0 +/- 1 degree ) Total/split ( 0 +/- 1 degree )
Camber........LH ( -0.03 +/- -0.75 degree ) RH ( -0.03 +/- -0.75 degree ) Total/Split ( 0 +/- 1 degree )
Toe.............Total/Split ( 0.18 +/- 0.20 degree )
Rear
Camber............LH ( -1.25 +/- 0.75 degree ) RH ( -1.25 +/- 0.75 degree ) Total/Split ( 0 +/- 1 degree )
Toe.................LH ( 0.12 +/- 0.18 degree ) RH ( 0.12 +/- 0.18 degree ) Total/Split ( .24 +/- .20 degree )
Thrust angle Total/Split ( 0 +/- .10 degree )
This is off a 2006 SEL V6 2wd
Thanks for the numbers. Now my next question is what CAN be adjusted on the car. As I understand it, there is no adjustment for the front camber. What about adjustments for the rear toe and rear camber? Is there updated parts that can be used so that the front camber can be adjusted?
