Is there any way to set the alarm so the horn will not sound when you set it?
This drives me crazy.
Just Press the locking button ONCE It will lock all doors and also arm the alarm.. :D
The "double Click" is just in case you want to verify that the car is locked and all doors,truck and hood are closed..
By the way if you press lock and the park/turn lamps DONT Flash once.. Something is open still!! :shock:
when i purchased my ford, it came with the upgraded alarm system...ford usually gives u the manual for it. to put the alarm into vallet mode.. turn the ignition on and off, and push the little red light. to take it out of vallet mode, do the same thing
