[quote author=fusion power link=topic=40929.msg618398#msg618398 date=1142391386]
ok. So im looking at the airbox. And to the right you have the tube that runs into the fender. But comming off the bottom of that tube you have a small tube going down into another black box about the size of the air filter box. And if you take off the tube that your talking about then that also means you have to take the tube to the other box out as well... Now my main question is what is that other box and is taking its tube out going to affect anything in a negative way?
[/quote]FOrgive me as I removed mine quite some time ago...I don't remember everything.
I took mine off and made sure that everything was pre-air filter, as in I won't be sucking un-filtered air. I am not quite sure what the 'other' box is that you are referring to, but I know I have one too. My thoughts is that if it was gaining and receiving air from the tube and I take the tube off, nothing is changed. It's still getting air from the location that the tube previously occoupied, right? If anything, it's just getting more air and the computer will figure out what to do with it, lol.
For real, I've had mine off about a month now and I've had absolutely ZERO problems. I've been in rain, sunshine and on the beach with sand flying around. I just took my filter out awhile back to look in the bottom of the box to make sure there wasn't no sand build-up, or some leaves or something in there...I was good to go!
