Are they ever gonna make one for us or are we going to be stuck with this plastic one??
F ForemansFusion08 · Registered Joined Jul 10, 2008 · 134 Posts Discussion Starter • #1 • Jun 10, 2009 Are they ever gonna make one for us or are we going to be stuck with this plastic one??
F FusionLife · Registered Joined Oct 8, 2008 · 1,728 Posts #2 • Jun 10, 2009 I wouldn't hold your breathe
F ForemansFusion08 · Registered Joined Jul 10, 2008 · 134 Posts Discussion Starter • #3 • Jun 10, 2009 i know but we can all wish
C chillin in the milan · Registered Joined Aug 30, 2008 · 1,839 Posts #4 • Jun 10, 2009 tsk tsk,fusion life,you know better than that
F FusionLife · Registered Joined Oct 8, 2008 · 1,728 Posts #5 • Jun 10, 2009 [quote author=chillin in the milan link=topic=147514.msg3171331#msg3171331 date=1244665985] tsk tsk,fusion life,you know better than that [/quote] ???
C crystallas · Registered Joined Feb 7, 2007 · 613 Posts #6 • Jun 11, 2009 There is nothing wrong with the stock intake manifold. People run boost on the same or similar intake manis with no related issues all the time.
C chillin in the milan · Registered Joined Aug 30, 2008 · 1,839 Posts #7 • Jun 11, 2009 theres the cosie that works with modifications,or if you get a tune made, you can get the stock one modified. its just a bitch todo
F ForemansFusion08 · Registered Joined Jul 10, 2008 · 134 Posts Discussion Starter • #8 • Jun 11, 2009 my stock one or focus 2.3L?? that'd be a lot cheaper than the cosie one.
C chillin in the milan · Registered Joined Aug 30, 2008 · 1,839 Posts #9 • Jun 20, 2009 you con modify the stock one you have in your car.but you need a tune for it to run right. and its a bitch to do.
2012 Fyousion · Registered Joined 16 d ago · 1 Posts #10 • 16 d ago On car i.d there a magnaflow manifold listed for the 2012 2.5l manifold with integrated catalytic converter MagnaFlow® - OEM Grade Stainless Steel Exhaust Manifold with Integrated Catalytic Converter Ford Fusion 2012, OEM Grade Stainless Steel Exhaust Manifold with Integrated Catalytic Converter by MagnaFlow®. Primary Tubing Diameter: 1.5". Collector Outlet Diameter: 2.5". Color: Silver. Header Coating: Uncoated. www.carid.com
