[quote author=frogger390 link=topic=191664.msg4040344#msg4040344 date=1307147504]
So the other day i was driving and the ac was blowing semi cold air then boom its blowing hot air.. so i thought i just needed it recharged so i got the stuff and had a guy i work with put it in cause i never done anything like this and he put almost a whole can in and it didn't blow any colder air at all its still blowing warm air.. WTF.. i am a little irritated.. u can hear the Compressor kick on idk what the problem is...
Hi frogger. :wavey: Unfortunate fact is that most air conditioning problems need to be checked/diagnosed by someone who knows what they are doing and has the proper tools.
For example, if your system has a leak, the refrigerant you refilled with could have leaked out just as fast as you put it in. Or, it may not even be a refrigerant/leakage problem and could be something else (in which case, your system may now be overfilled, which is not good either).
Anyway, best advice I can give is to have it looked at by someone qualified to diagnose HVAC issues.
Whatever you decide to do, good luck. :cheers:
