1 - 10 of 10 Posts
Over the past few days I've noticed my A/C was'nt blowing as cold. At first I thought it was because of the heat but now it's blowing hot. I used an A/C thermometer and with the climate control at set at 60 I measured 76 degrees! 12,000 miles and the A/C is messed up? Fuckin Ford. I'll be taking it in to the dealer this week to see what happened. Will post with update.
:shock:
Dude if you have any questions........ I have a PhD in this problem.....
Well I finally took the car to the dealer today. A defective condenser leaked all the freon out. Of course, no condenser in stock so I should have it back tomarrow afternoon. From what the service adivsor told me quite a few of Fusions, 500s and Foci have had this problem.
Picked up the car yesterday, the condenser was replaced and got a fresh charge of freon. AC was blowing nice and cold....for the day. Today about noon it was, and still is, blowing hot!! Got an appointment for monday. We'll see what they say this time.
been there done that. Tell em to check for Blockage in the line or better yet, tell them to blow out the line. If it helps, tell you service rep to give Kimnack Ford in Norfolk, VA a call. They are very well "versed" in this problem having my car in thier shop for almost a month....
similar problem here.....high pressure line coming to compresor unit is leaking....dam green liquid scared me...i tought it was the anti freeze..but i was like wait.....the anti freeze in this car is yellow.....so WTF....did some searching and ....there it was.....leaking from the AC compressor....shit....1st problem ...
[quote author=Hispeedsoldier link=topic=56118.msg958723#msg958723 date=1158549248]
What ended up being the final solution to your problem?
a coupled of Clutches, compressors, dryers, AC fuses, and 29 days later they found "Blockage" in the line. Blew it out, recharged it, and it has been working fine ever since.
1 - 10 of 10 Posts
