[quote author=springer03 link=topic=85314.msg1669702#msg1669702 date=1188120286]
You need these than your rims will fit.
http://www.ezaccessory.com/Wheel_Adapter_5_Lug_4_5_To_5_Lug_4_5_p/5450-5450.htm
The hub centric is larger on Milan, 67.1 Montego is 63.5
Machine shop can bore if you don't want adapters.
Do you know if a one inch thick adapter can be mounted on the original lug studs with stock lug nuts and not interfere with the wheel? I am thinking the studs will stick out of the face of the adapter. Also it looks like the adapters provide no hub centering shoulder at all. Are there problems with off-center mounting with these adapters?
I got a decent deal on these wheels, but I doubt I will drop another $140 on adapters. I'll check out the option of having them machined or else just re-sell them and try again with different wheels that will actually fit my car.
Thanks for the help. It is nice to see another I4 Milan on the forum.
