2017 ford fusions hybrid se not driving
237 Views 1 Reply 2 Participants Last post by  bbf2530
I just bought a 2017 Ford fusion from a auction. The car will start go into gear but wouldn't move in drive or reverse. The dash a
Has a pull over safely light and some tire light that's all I can remember. Can anyone point me in the right direction for help?
Hi Jammin and welcome to the Ford Fusion Club. Unfortunately, blind Internet diagnosis, with minimal information, for a problem like this will not be of much help. For example...what is "some tire light"?
Where to start? Well, having the vehicle system read for any stored DTC codes would be very helpful, as that may point you in the right direction. However, the vehicle can not drive, you can't take it to a big box auto store (i.e. AutoZone etc) where many will scan for codes for free, or a Ford Dealer. So in this case, you may need to buy a good OBDII code reader in order to scan for codes yourself and hope it can point you in the right direction. Or use FORScan software with an OBDII/USB connector and laptop computer.
In reality, this will likely be the type of project which will need professional help from a shop that does Hybrid vehicle work.
You can also research what "some tire light" is with the Owners Manual. If you did not get a hard copy, you an download the PDF version here: https://www.fleet.ford.com/parts-service/resources/owner-manuals/
Perhaps one of our Tech members will also jump in with more assistance.
