1 - 1 of 1 Posts
New here. Have a 2016 Fusion SE. The blend doors that open the vents to defrost, front and floor vent are shut and will not open. AC and Heater work, just no air flow. Reading that the blend door actuator is not working.
I am looking for the location of this actuator and the correct one.
Unless there is something i can do to try before replacing it? Seems like it's a common problem of the actuator failing.
Thank You
1 - 1 of 1 Posts
