Any help will be appreciated.
Rattle from shocks or mounts? How can you fix this?
Hi meamorey1 and welcome to the Ford Fusion Club. It is extremely difficult to blind Internet diagnose sounds and noises. Far too many suspension and drivetrain components up front to do anything other than make somewhat educated, but in the end, still only wild guesses. There are shocks/struts/mounts, bearings, control arms and their connections/bushings, swaybars and end links, etc. etc. etc.
Therefore, you will need to diagnose/isolate the component/components causing the rattling, then either tighten the component if it's only loose, or replace the component if it is worn and at end of life.
If you can not do that yourself, or with the help of a friend/family member, then you will likely need a shop you can trust to do so.
I'm sure others will jump in with more suggestions and advice.
