Not even sure what to say about this, but it is a major problem.
This has happened 3 times now. Once about a month ago, and I thought it was a fluke. Then it happened twice today about 2 hours between both instances.
2013 Ford Fusion Titanium with push button start and remote FOBs.
Not only does it scare me that it is shutting off while driving, but if the key fob is in range, it actually seems to be able to start the engine.
I took 3 videos of it happening. Videos 1 and 3 show more of what is happening.
During the videos, I am just sitting in the car. Not touching the brake pedal, not pressing the start engine button, not doing anything with the key fob. I even took the battery out of the key fob, and it still does it, but at least can't start the engine.
Battery is 2 years old. I checked for corrosion and connection tightness and that was good. Grabbed the voltmeter and am getting 14.3v when running and it is holding (no longer dropping) 11.9v after sitting overnight. That technically is a "dead battery" but it never has an issue starting or running anything when not having this problem. I was still able to start the car 2 days ago and let it run for about 3 minutes (while I tested the running voltage). Now it is reading 12.3v after sitting. So inconsistent... Yes, I tried two voltmeters. A newer one, and a really old one that I had, and they both read the same to the first decimal place (old one doesn't get more specific than that).
Thoughts on where to start?
- Car is started normally sitting in the car, pressing the brake pedal, pressing the start button.
- Car is put into gear (forward or reverse) and start to drive.
- Car at an undetermined amount of time, but so far within the first 30-60 seconds of starting, will just shut off all electricity. Not just kill the engine, but everything on the dash or infotainment system turns off some times, but not all times.
- Then power will come back, and then off again, and then it will even start the engine itself, shut down again, sometime just start in "accessory" power mode (not full engine start), and off.
