My 2011 Ford Fusion SEL interior lights are staying on all the time. I cant seem to get them to shut off. I know that this is going to kill my battery. anyone out there know how to solve this? I do have a scanner as well as FORSCAN availble so if anyone knows a trick with that it'll be great
09 Fusion SE 3.0L V6
Check first that all your doors, trunk and hood are closed completely. My 09 Fusion SE will leave the interior lights on all the time if any of those is open even a little. If that's not the case, could be a faulty door switch that's not telling the computer that the doors are closed.
2012 Fusion Sport AWD
They are not turned on with the switch right? Does it complain about any open doors that are not open?
To turn off the "Dome On" you press the down arrow side of the instrument cluster dimmer switch. It is possible that the dimmer up button was pressed and held long enough to turn on the dome lights (it first has to make the instrument cluster lights fully on).
