Helllo....Does the entire brake assembly light up when the brake is pressed or does only the center portion light up??
thx!
thx!
Hi RB. Welcome to the Ford Fusion Club.
Yes, only the center section illuminates.
Only the center 6 LEDs. I’ve wondered what can be done to light the whole thing
Hi Don. Remove and open the spoiler CHMSL housing. Add LED strips (which likely may not match the factory LED's brightness, looks etc.) or bulbs (same, plus the bulbs won't really look correct). Wire the LED strips or bulbs into the CHMSL taillight circuit. Properly seal and close the housing to avoid condensation.
Not too sure about how worth it this would actually be to try.
Keep us updated if you decide to do it, and good luck.
