Hey everyone! Have an issue with my sunroof. It operates perfectly fine, but the piece that the glass resides in when it closes is warped. So, the glass does not snug into this piece of plastic correctly, therefore the roof does not close unless I use my hand to guide it in.
What is that piece part number, and a way to replace it. I would like to open the roof again!
The tilt function is fine, as the glass does not leave that plastic holder.
Any assistance would be greatly appreciated.
Thank you.
Read this thread, post #10 shows how to reset the moonroof position.
Not sure if your issue is the same from your description.
I have the same issue. Sometimes more then often. The little plastic deflector that pops up when open held in by screws and fabric is either worn out or need tightening. And those little metal arms that connect to plastic peice could be bent
