Vehicle: 2010 Ford Fusion SEL FWD I4 Automatic
Hi,
My vehicle (above) had its passenger light go out.
I tried replacing the bulb and nothing happened.
I eneded up using my multimeter and discovered it has around 8-9 volts compared to the driver side @ 12.5 Volts.
Any idea what is causing the voltage to drop and not turning on the light?
Bad Ground?
Thanks,
Hi,
Bad Ground?
Thanks,
What is a "passenger light"?
Discussion Starter #3
Good Point.
It's the passenger side low beam headlight.
I did a few tests with my multimeter yesterday and its getting a constant 9.5V, my conclusion is that the wire is bad, too much resistance...ohms law correct?
However, due to the fact that its within the headlight assembly, I was advise to use a piercing probe and test the wire about 1-2 inches below the connector to validate if the wire is bad.
