21 - 30 of 30 Posts
Sweet info thanks guys i just bought me some new rimes there 18x8.0 with a 40+ offset i was wondering if a 235/40/18 would be good i was wanting to do 24/40/18 to have a wider tire but im think that the 235s will do thanks guys.
Jaysen, am I right to assume that the stock wheel from the factory, and tire size for my 2010 SE is:
225/50/17 tire on a 17" x 7" rim with 35 mm offset?
Based on the stock wheel tire combo that came on the car (225/50/17) tire on a 7” wide rim and 35 mm offset/ET. . .
I’m considering the staggered look with an increase in the rear. Was speaking to someone over at Steeda, and they offer wheels specifically for that application, and for the Fusion. I can opt for a rear wheel that is 10” wide.
The car is never raced. Nor is it driven to “the limit”. Someone else mentioned that if it’s truly a concern that changing out the rear sway-bar would alleviate the issue, but would be a waste of time.
The car is a daily driver, and these wheels and tires will only be utilized between the months of April to October. The factory 17s (225/50/17) with the Winter tires mounted will go back on from November to March.
Basically I would be running:
Fronts: 245/35/19 on an 8.5” wheel/rim with offset(ET) of 37
Rears: 265/35/19 on a 10” wheel/rim with offset(ET) of 42
21 - 30 of 30 Posts
