So im looking to finally get me a second key. Trying to figure out which one I need though. Want to try buying it other than Ford since they wanted $60 when I asked a while ago.
Opened up the key chip/fob compartment. Found the following:
FCC ID: OUCD6000022
IC: 850K-D600002
(below that): 6U5T-19H316-AB
- Also mines is a single press trunk release.
Not sure what the part number would be (164-R7013, 164-R7040, or if something else). Saw keys with single press trunk release button and double press trunk release button. From what I've read on some is that it's interchangeable (the P/Ns and the buttons).
So does it really matter which one i pick?
If you don't currently have 2 keys, you won't be able to self-program any additional keys.
If $60 is what the dealer wants to supply and program the key, that sounds more than reasonable.
