Im about to rotate these things does anyone know the proper torque they should be at? I have a torque wrench so no reason not to torque them properly.
its a 2007 fusion
[quote author=ciscoford23 link=topic=93029.msg1815405#msg1815405 date=1193601227]
The torque spec. is 133 Nm (98 lb-ft). Also tighten them in a star pattern if you didn't know that already.
cisco
Werd! I always go back around in a circle after the star. Just to make sure everything is tighten down.
cisco
Hi cisco. :wavey: If I access the 2007 Fusion Owners Manual online, through the Ford site, it recommends 135NM (100 lb-ft).
I only double checked the specs you provided because I knew my 2007 MKZ Owners Manual recommends 135 NM (100 lb-ft), as I always re-torque the lugnuts when I have my tires rotated.
I know it is not much of a difference, but it is a little higher torque rating.
Good luck! :cheers:
cisco
yeah you don't want to bend the rotors
[quote author=bbf2530 link=topic=93029.msg1816350#msg1816350 date=1193638511]
cisco
Good luck! :cheers:
Thanks for the heads up. That is weird that the service manual and owners manual would be different. Like you said it isn't much but still should be the same.
