So i've got an 07 Lincoln MKZ that came with the stock halogen lights, I bought a pair of OEM Lincoln MKZ HID headlights with the bulbs and ballasts. I plug them in and they work great when the car is NOT started. As soon as I start the car they go out and the Error Messages turn on, on the dash. If i connect and disconnect one while the car is started it blinks for a fraction of a second then goes out.
It seems like when the car is not on there is no diagnostic feature going through everything, but when you turn it on, the diagnostics kick on and it shuts off the lights. I assume its because the HID's are drawing less power than the halogen's and it's cutting power to the lights when it thinks the bulb is out. This is not my first rodeo with HID's but this is the first time something like this is happening, probably due to it being a stock setup.
Will the Error Message Eliminator kit work for me or do I have to splice in a resister to match the difference in voltage requirements? I talked to the dealer and they said to come in to check it out, couldnt give me an answer over the phone because no one knew... sounds pricey. Most likely they would have to reprogram the ECU to accept the different voltage requirements....
