[quote author=07blackSEL link=topic=166641.msg3532798#msg3532798 date=1265408996]
Hey guys I have an 07 V6 Fusion with almost 60k miles on it. Today when I was sitting in a drive through I noticed that my engine was making this clicking noise. I thought maybe it was the car behind me so I shut the car off and the sound stopped. Turned it back on and there it is again. Is it normal for these engines to make a clicking noise while idling?
Hi 07black. :wavey: Trying to diagnose an engine sound over the Internet is virtually impossible.
Our engines are DOHC (Double Overhead Cam), and some may normally exhibit a "ticking" sound, to varying degrees. You can also get an intermittent "cicking" sound when the A/C condenser cycles on and off. This could occur if you have the HVAC set to "AUTO" or the front defroster on, for example.
However, there is no way for us to determine if what you are experiencing is a "normal" engine sound or not.
All you can do is perform the various maintenance checks that we all should do anyway: Do you change the oil on schedule (6 months/5,000 miles for your model year)? Have you checked the oil lately? If not check and top off if necessary.
Other than that, if you still have worries that it is something out of the ordinary, do as Gravey stated above and make a service appointment with your Ford Dealer if still under Warranty. If no longer under Warranty, make an appointment with your Ford Dealer or your own mechanic (if you have one), whichever you prefer.
If you are not sure what the noise is, better safe than sorry.
Keep us updated.
Good luck. :cheers:
