2013 Cabin Air Filter Location - FordFusionClub.com : The #1 Ford Fusion Forum
Old 05-06-2013, 02:43 PM   #1
chris102984
Bicycle Rider
Default 2013 Cabin Air Filter Location
Has anyone changed their cabin air filter on their 2013 model yet? If so, how do you get to it? I've read that the previous generation had the filter behind the glovebox (that's how my wife's Toyota is, as well as my old Toyota). Any help would be greatly appreciated.
chris102984 is offline   Reply With Quote
Old 05-06-2013, 11:37 PM   #2
lawrence
Go-Kart Driver
lawrence's Avatar
Default
i would also like to know this with all the pollen in the air i want to change mine
lawrence is offline   Reply With Quote
Old 05-06-2013, 11:57 PM   #3
nightrunner06
Moped Rider
nightrunner06's Avatar
Default
I believe it is behind the glovebox
nightrunner06 is offline   Reply With Quote
Old 05-07-2013, 08:52 AM   #4
chris102984
Bicycle Rider
Default
Quote:
I'll agree with that one per the owner's manual, but it also says to take it to a dealership to have the filter serviced. I'm starting to contemplate ripping the whole passenger side of the dash apart, allergies are horrific this year and I'd like to swap in a new filter to ideally ease them a bit.
Old 05-07-2013, 09:14 AM   #5
lawrence
Go-Kart Driver
lawrence's Avatar
Default
i personally am so tired of seeing this "see dealer" bullshit why is ford being this way id expect it out of bmw but come on
Old 05-07-2013, 11:53 AM   #6
chris102984
Bicycle Rider
Default
Quote:
It seems everyone is heading that direction. I had a VW that recommended having the dealership replace the headlights. When I went to take care of it myself I learned why though, I had to take out the battery among other things to get access to the front left light.
Unfortunately you have to count on lowest common denominator, and there's quite a few less than intelligent folks out there that would screw things up, hurt the car (or themselves), and then try to sue Ford for it.
Old 10-17-2013, 08:05 PM   #7
twintornados
Moped Rider
Default
Here is a quick video of how to do it. I think that you should be able to lift the glove box door off without having to take the entire assembly out like the guy in the video did. My 2012 Fusion SEL is a 5 minute job. Remove tension wire so that the glove box drops all the way down when you squeeze in the side stops that prevent the glove box from flopping open to the floor. Lift the glove box out of the glove box frame and the filter should be accessible from there. I have not seen a break down of the parts, but it is only my speculation of how the glove box door comes off using my 2012 as a benchmark.
New: 2012 Fusion SEL 2.5L in Cinnamon Metallic.
Traded: 2006 Fusion SE 3.0L in Silver Frost
twintornados is offline   Reply With Quote
Old 12-09-2013, 03:39 AM   #8
me32
Short Track Racer
me32's Avatar
Default
Wtf was ford thinking when they set this up. It take 2003min to change a cabin filter. The mustang is so much easier.
2014 Tuxedo Black Ford Fusion
-Stock
2008 Shelby GT500
2921 out of 6513 coupes
132 of 314 Alloy Metallic
Shelby Dash Plaque,FRPP TVS Super power pack ,Drag Pack,SVT handling pack,FRPP Cobra Jet TB/MAF/80lb injectors,J&M UCA,LCA,Adj.PHB,SFC,PH A/D,O/R H, DynoMax 3in,CHE, Shelby Rad/HE,VMP 2.59,KB BAP,L&M plenum,BMR KMEMEBER,AED CUSTOM RETURN STYLE FUEL SYSTEM.
91/E85 tune by SHAUN AT AED
700HP/700TQ ON E85
10.78 @ 129MPH 1.644 60FT
me32 is offline   Reply With Quote
