2013 Fusion Low Beam and Fog HID Install - FordFusionClub.com : The #1 Ford Fusion Forum
Old 11-24-2012, 07:34 PM   #1
larryinfl
Le Mans: Prototype Class
Default 2013 Fusion Low Beam and Fog HID Install
Just wanted to post up some info on my HID install for my lows and fogs I did this weekend on my 2013 Fusion.
Getting to the bulbs is not that easy. The manual actually tells you to have your dealer replace you low beam bulbs for you. The manual actually tells you to see the dealer to replace nearly every bulb in the car.
I went with 55w 6k for my lows and 35w 6k for my fogs.
A few notes:
1 - I needed a relay harness for my low beams. My lows would not come on at all when the car was on. They did work fine if the engine was off. But as soon as I started the engine they would go out. I did not need a relay harness for the fog lights.
2 - I removed all the easily accessible bolts that were holding the headlamp. It allows you to move around the headlamp a bit to make reaching in for the bulb a bit easier.
3 - While installing the driver side fog was very easy, the passenger side is a PITA. The windshield washer fluid tank is right behind the light. So you need to reach under and up to get to the bulb. Putting the HID bulb in and tightening was a PITA. I ended up getting it in place and then used some pliers with tape on the end (to not damage the wiring) to tighten it.
My parking lights are super yellow in comparison. So I just orders some LED bulbs off of ebay for about $7. The parking light bulb size is: W5W
I'll try to get a pic soon to post it up here.
larryinfl is offline   Reply With Quote
Old 11-24-2012, 11:57 PM   #2
elodam
Moped Rider
elodam's Avatar
Default
planning on doing this... just didnt know where to begin on this car... pics would be greatly appreciated
elodam is offline   Reply With Quote
Old 11-26-2012, 12:22 AM   #3
wireless
Le Mans: GT Class
wireless's Avatar
Default
I'm curious to see the output. Please post some pictures on a wall at 25' at least.
I don't own a Fusion anymore. I drive a GTI.
'10 Sterling Grey Fusion SE 2.5L, EvoX-R retrofit
wireless is offline   Reply With Quote
Old 11-26-2012, 08:27 AM   #4
larryinfl
Default
I did some tweaking to the aim of the headlights last night. They were a bit too high. I don't have a flat surface to do a proper adjustment at home. I'm hoping to have some time tonight after work to do some tweaking here at the office. I'll try to get some pics.
Old 11-26-2012, 08:40 AM   #5
wireless
Le Mans: GT Class
wireless's Avatar
Default
Sounds awesome! I'm curious to know if the 2013+ Fusions have foreground limiters on their projectors. I know the bixenon projectors that the Fords are using now are Hella E55 variants, so the EvoX-R is a direct swap and a much better projector, esp. if a custom foreground limiter is put onto the EvoX-R.
But yeah, keep us updated, I'm very curious to see how the beam pattern is.... I really hope it's not laser-beam esque like the 2010-2012 lol
Old 11-26-2012, 01:03 PM   #6
Iwantanewcar
Bicycle Rider
Default
Larry,
Where did you get the HID's. I have always used HIDExtra, but have read some really bad reviews lately and think that the HID Extra company that I bought my lights from is a different HIDExtra company then the one that exists today.
Thanks
Iwantanewcar is offline   Reply With Quote
Old 11-26-2012, 02:26 PM   #7
larryinfl
Default
I get mine at vvme.com. For the price I think they are the best you can get. Typically in this price range you run into issues. But I've installed several kits from them with no issues and you can find a good bit of vvme users on this forum as well.
Old 11-26-2012, 02:31 PM   #8
seasonalskier
Senior Member
seasonalskier's Avatar
Default
Theretrofitsource.com sells an excellent HID kit from Morimoto. It comes with everything you would need to install it and the quality is top notch, well worth the extra money IMO. And it also comes with some of the best customer support I have ever seen.
Old 12-04-2012, 06:31 PM   #9
elodam
Moped Rider
elodam's Avatar
Default
Did you have to remove the bumper??
Old 12-07-2012, 02:21 PM   #10
larryinfl
Default
Nope.
Similar Threads
Thread Thread Starter Forum Replies Last Post
2013 Fusion Review Chrisz Consumer Reviews 0 11-17-2012 08:57 PM
2013 Fusion SE bicker I Just Got My Fusion, Milan, Zephyr or MKZ! 3 10-10-2012 01:37 PM
2013 Fusion App seasonalskier The Fusion, Milan, Zephyr, MKZ & Ford in the News 7 12-14-2011 10:31 PM
2013 Fusion..? Cn87 The Fusion, Milan, Zephyr, MKZ & Ford in the News 21 12-07-2011 12:50 PM
Do you think that the 2013 Fusion Rims... jdebo Wheels / Tires 3 11-30-2011 06:29 PM
