Remove leather seat cover? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 03-31-2012, 02:20 PM   #1
lyonsroar
Le Mans: Prototype Class
Default Remove leather seat cover?
Is there a way to remove the drivers side leather seat cover? The padding or some other component has bunched up on the far side bolster on the bottom seat. It doesn't look real good so if it's not too hard to do I'd like to take the cover off and un-bunch it.
2006 Ford Fusion SEL
~Not even CLOSE to stock~
lyonsroar is offline   Reply With Quote
Old 04-11-2012, 02:53 PM   #2
Cinjent
Go-Kart Driver
Default Re: Remove leather seat cover?
yes in deed. it's not very complicated either. you will find it simple to remove the four bolts securing the seat, then disconnect the wiring, and pull the seat out through the back door. at this point, just be bold. it is not difficult to remove the cover, just takes a little time.
Cinjent is offline   Reply With Quote
  FordFusionClub.com : The #1 Ford Fusion Forum > Ford Fusion Visual / Audio > Interior Modifications
