My Spark Plug Story... 07 3.0L - FordFusionClub.com : The #1 Ford Fusion Forum
Old 03-03-2012, 04:47 PM   #1
huntersteve61
Grand Am Series
Send a message via AIM to huntersteve61
Default My Spark Plug Story... 07 3.0L
So I was going over my fusion with a careful eye this week when it occured to me.. 68,000 miles.. Maybe I should pull a plug and see how things are looking. Upon doing so I noticed the tips were worn and the plug overall needed replaced... So, having an auto repair garage, I got on my commercial account and pulled up my car to look at the options.. We all LOVE pictures right.. So I'm looking @ everything from Autolite XP's to Motorcraft OE...
Now the exciting part.. I did the research and decided yea, lets go oe because I haven't done anything performance so what will I really see in spending 7+ a plug for the autolite's.. Well according to autozone and napa.. My motorcraft plug SHOULD BE an SP433... Which factory number is AGSF 32WM... WHAT I ACTUALLY HAD was AGSF 32N... Interesting I thought so before I accepted what I was being told to be OE I decided to try FoMoCo.... Yet again.. same story....
Talked to a tech @ a bar thursday night who said he recalled the ford 500 3.0L running an SP413, AGSF 32N.. Now we're getting somewhere... This plug is Nickle grade and not rated past 50,000 miles.... He went on to explain the new factory spec is this SP433 which is 100,000 mi RATED plug..
To sum the whole story up.. IF you own an 06,07,08 with a 3.0L You possibly have the inferior nickle plug and you should probably invest in a tuneup and the SP433 plugs.. It cleared up my early morning roughish idle and my light hesitation.. IMMEDIATELY!
Thanks for reading I truly hope this helps someone down the road
huntersteve61 is offline   Reply With Quote
Old 03-03-2012, 06:18 PM   #2
ericthered
Short Track Racer
ericthered's Avatar
Default Re: My Spark Plug Story... 07 3.0L
Hi huntersteve61, I too checked my plugs early( around 38-40,000 miles ) . I noticed they were a little worn. I changed them for Bosch platinum4 ( another story, they suck!! ) and it ran like crap. Changed them to Autolite upgrade plugs and also cured a cold start miss. Good catch!
2007 Ford Fusion SE V6 AWD
Magnaflow mufflers
K&N Typhoon intake Autolite double platinum plugs Silverstar ultra high and low beams Silverstar foglights. HD Front lip
Roush lower grill
ericthered is offline   Reply With Quote
Old 03-03-2012, 06:44 PM   #3
Big Jim
Le Mans: GT Class
Something to be aware of is the Autolite is the main vendor for spark plugs for Ford. Autolite XP is essentially the same as the Motorcraft fine tip equivalent.
Big Jim is offline   Reply With Quote
Old 03-04-2012, 10:55 AM   #4
cmillls45
Short Track Racer
I've got an '08 3.0L with 52,000 miles. Checked one of the plugs and indeed they're AGSF 32N. Looks like I'll be swapping those out here soon. I'm guessing it's a bitch to take out the intake manifold?
Silver Birch, leather, moon and toon, K&N air filter, weather tech floor mats, Ford Flex shift knob, clear side markers, shark fin, molded splash guards, chrome turn signals, color matched fog light bezels, debadged, resonator delete.
cmillls45 is offline   Reply With Quote
Old 03-04-2012, 11:11 AM   #5
cmillls45
Short Track Racer
Well I just called Ford. They did say the replacement part # is AGSF 32WM. I asked him what the difference between 32N and 32WM and he said the 32N was original part and the 32WM is the same plug, just the replacement part #. Both role up into the SP433 and are good for 100,000 miles.
Anyone else have thoughts on this?
Old 03-04-2012, 11:53 AM   #6
Big Jim
Le Mans: GT Class
I agree that both plugs are 100,000 mile plugs. That doesn't mean it is a good idea to go that far. I intend to change the plugs on my wife's 03 Escape at 80,000 miles. At her current rate of use, that will likely be next year sometime.
Worn plugs take more voltage to fire, especially when the under load is high. Forcing a coil to work above its ideal voltage rage is rough on the coil, and is likely a prime cause of coil failure. A brief explanation is that the voltage required to fire the plug varies considerably during driving due to various conditions, but mostly due to cylinder pressure. The higher the pressure, the more voltage needed. Other factors include fuel to air mixture, temperature of the air / fuel charge, and cylinder head temperature.
As to the part number difference, I would have to see the plug, but I do know that often the replacement plug is threaded further up the plug, but the tapered shoulder that determines how deep the plug goes into the head is in the same place. That makes the plugs interchangable, but just with extra threads.
The main thing that determines plug life is the materials in the firing zone. That is the center wire and the side wire. Of the two, the most critical is the firing wire which on our cars is the center wire. Engines with coil packs fire half of the engine from the center wire and the other half from the side wire (reverse polarity). Our cars use iridium on the center wire because of its superior erosion restance. On the side wire, platinum is used. Platinum is still much better than steel, but the side wire does not erode nearly as much as the center wire.
Although you can use plugs with a different configuration of the firing wires, the fine wire iridium center and platinum side wire has proven to be the longest lasting trouble free configuration. Double platinum using a larger center wire doesn't hold up as well, and the multi side wire plugs (such as Bosch +4) are just plain junk in our engines.
As far as brand is concerned, Motorcraft is what the engineers specified (they told the vendor what they wanted and the vendor built it to Ford's specs, although there is some of the vendor saying this is what we have, what do you need). Autolite, the prime spark plug vendor, makes plugs under their own label that are either identical or very nearly so.
NKG furnishes some Motorcraft plugs, especially for engines that are bound for Europe. You can easily tell them because they look like an NKG but with the Motorcraft label. Ford's replacement plugs for those are usually supplied by Autolite. Anyway, NKG is usually a high quality plug and works well in our cars, but often priced at a premium with no real benefit from the higher price.
Old 03-04-2012, 12:32 PM   #7
Fus1on.
Grand Am Series
[quote author=cmillls45 link=topic=204604.msg4194822#msg4194822 date=1330876555]
It doesn't look too hard
http://img37.imageshack.us/img37/3095/intakereminst.jpg
'08 Ford Fusion SEL
Fus1on. is offline   Reply With Quote
Old 03-05-2012, 03:39 PM   #8
huntersteve61
Grand Am Series
Hey the plug looks the same except for the tip. The 32N is nickle plated "platinum" plug. The SP433 plug is the same physical plug with double platinum and finewire design. Reguardless the N series is now inferior therefore CHANGE!!! And 100K is such overkill.. I was already having light miss at cold start with 68,000.
As for the intake its easier than you think! Remove intake, unbolt electronic Tbody, unbolt egr and unplug 1 sensor on left back of plenum. Loosen the 8 bolts and pull it up and out towards you. While its out wipe out the Tbody, the egr, and replace the plenum gaskets. I can provide the part numbers should you need them for felpro gaskets! took me 2 hours and I had a buddy show up midway and talk my ear off.
Cheers!
Old 03-17-2012, 04:55 PM   #9
fox fader
F1 Driver
[quote author=Fus1on. link=topic=204604.msg4194843#msg4194843 date=1330882370]
Took me a bit less tha 2 hours to change my plugs. It's not hard at all.
'06 SEL V6, leather, roof, 20% tint, lightning audio 3-ways, super tweets, 6000k fogs, flashing sides, LED maps, and tag display.
'13 Focus ST
'98 Saab 900 SE Turbo FAST!
'01 Aprilia RST 1000 Futura
fox fader is offline   Reply With Quote
Old 04-07-2012, 11:46 PM   #10
fus10
Short Track Racer
I just did my tune up today. Took me 2.5 hr I have kids
Wasn't too bad to do myself. My hardest part was getting the dang
Plenum to pull out after loosening it.
I too had the AGSF 32N as the original op had.
My plugs looked worn. I am at 79,000 miles. This thread
Helped me in performing this task myself.
fus10 is offline   Reply With Quote
  FordFusionClub.com : The #1 Ford Fusion Forum > Technical / Model / Performance for the Fusion, Milan, Zephyr > Engine & Drivetrain > V6 Engine Discussion
