TSB 11-3-22 - FordFusionClub.com : The #1 Ford Fusion Forum
Old 07-23-2011, 01:53 AM   #1
con_fusion
Moped Rider
Default TSB 11-3-22
I was looking at this site which listed a TSB 11-3-22 as being applicable to the 2010 Fusion: https://www.eautorepair.net/app/TSBS...PS=2&MA=15
Just wondering if anyone has seen the text on this as to what exactly it is.
The summary is: DRIVEABILITY SYMPTOMS WITHOUT DTCS OR DRIVEABILITY SYMPTOMS WITH DTC P144A, P2196, P2198, P1450,
Thanks
con_fusion is offline   Reply With Quote
Old 07-23-2011, 09:12 AM   #2
bbf2530
Default Re: TSB 11-3-22
[quote author=con_fusion link=topic=193868.msg4077156#msg4077156 date=1311400404]
Thanks
Hi con_fusion. If no one else can provide the information you need, I would recommend you send a PM to ciscoford23 and ask him to provide the TSB information. While he is not around the FFC as much anymore, he has been very helpful to myself and others in the past with technical information. Provide an E-mail address in the PM and he will usually send the information directly to you.
And again, he is not around as much so be patient.
Old 07-26-2011, 11:56 PM   #3
con_fusion
Moped Rider
Sounds good.
Thanks
  FordFusionClub.com : The #1 Ford Fusion Forum > Ford General Discussion > Ford Fusion / Mercury Milan / Lincoln Zephyr & MKZ > TSB / SSB / Recall Information
