TPMS-"BYPASS" - FordFusionClub.com : The #1 Ford Fusion Forum
Old 06-21-2011, 12:15 PM   #1
indycop
Short Track Racer
Default TPMS-"BYPASS"
My brother found on the internet a way to "bypass" the TPMS--sort of. Put the sensors in a sealed tube with a valve stem on it and pressure to 35 PSI and secure tube in trunk--computer will be fooled and you 07 and up guys can enjoy what wheel suits your taste.
Thanks 09fusion57.
2006 V6 SEL Dark Blue Pearl/Black Leather
Magnaflow-Steeda CAI/Strut Bar/Rear Sway Bar
Mustang 18x8.5 Fan Blade Wheels/General UHP 245/40-18
Ford racing springs-Tokico dampers. Steeda lower engine mount.
indycop is offline   Reply With Quote
Old 06-21-2011, 12:18 PM   #2
koreySE
Le Mans: GT Class
Default Re: TPMS
I don't think this works for all. Some require motion.
'10 MKZ AWD: White Platinum, Ultimate/Technology/Sport Packages. 20% tint, Steeda intake w/Airaid SynthaMax filter
koreySE is offline   Reply With Quote
Old 06-21-2011, 12:21 PM   #3
indycop
Short Track Racer
Default Re: TPMS
[quote author=koreySE link=topic=192480.msg4054254#msg4054254 date=1308669482]
Will it work for ALL Fords/Fusions? (If it ain't a Ford product--who cares? LOL)
Old 06-21-2011, 01:33 PM   #4
bbf2530
Default Re: TPMS
[quote author=indycop link=topic=192480.msg4054262#msg4054262 date=1308669719]
Hi indycop. Others have tried this in the past and it does not work on the Fusion/Milan/MKZ. At least not with the "band-type" sensors used on the 2008-2009 models. They are the motion-sensitive type and will only send signals while rotating. While I am not positive about the 2010-2011 valve-type sensors now being used, if I recall correctly those who have tried reported the same results.
Old 06-21-2011, 05:41 PM   #5
koreySE
Le Mans: GT Class
Default Re: TPMS-"BYPASS"
I can say that on my '10 Focus (stem sensors?), my TPMS fault would clear every time I started my car in the garage with my sensor-less winter tires -- with the OE set stored nearby. This tells me that motion was not required on it? Either way, I would still drive with a light on before going through the hassle of removing the sensors (cost), building a device (more $), etc -- for a winter set. On a full-time wheel replacement, I'd spend the $ on the rebuild kit.
Old 07-05-2011, 03:29 PM   #6
Chris00gt
Short Track Racer
Send a message via AIM to Chris00gt Send a message via Yahoo to Chris00gt
Default Re: TPMS
[quote author=bbf2530 link=topic=192480.msg4054311#msg4054311 date=1308673993]
Hmm....if I have my factory wheels in the garage and have my TPMS comes on the way to work due to my snow tires being on, it will reset the next day when I start my 2009 Fusion up next to them.
2009 Ford Fusion SEL V-6, Blue Suede, Moon & Toons, Remote Start, Magniflow cat-back, Steeda Cold Air, Steeda SCT tune-93 octane, Steeda strut tower brace, Steeda rear sway bar, GTSPEC rear trailing braces, Steeda x-brace, Megan H brace, Steeda TB spacer, TB coolant delete mod, Fluidamper Underdrive Crank Pulley, Steeda Motor Mount, Engine Cover, Red Line hood struts, Hidden trailer hitch.
2000 Saleen S-281 SC 530rwhp &460rwtq (SAE)
1991 Saleen H/C/I with NOS
Chris00gt is offline   Reply With Quote
Old 07-05-2011, 08:24 PM   #7
bbf2530
Default Re: TPMS
[quote author=Chris00gt link=topic=192480.msg4064302#msg4064302 date=1309890559]
Hi Chris. Are you sure the system is not simply resetting because you are restarting the car? Like many other systems in our cars, I believe (but am not 100% sure, since my car does not have TPMS, and I have not checked the later model year Owners Manual for this particular issue) it resets when the car is restarted.
Old 07-05-2011, 08:34 PM   #8
Chris00gt
Short Track Racer
It only does it when I park the car next to my my factory wheels in the garage. If I park outside away from the wheels, the light will remain on. Just one of those things that make you go hmmm ;-)
Old 07-05-2011, 08:38 PM   #9
The Only MTS
F1 Driver
Send a message via MSN to The Only MTS
The 2010 resets even though they are in the shed, then after about 2 minutes out of the driveway... on it comes. Biggest piss off, Ford did not make the TPMS reverse compatible. The 09 SAP wheels with the bands are on the 2010, but need to get some newer sensors
The Only MTS is offline   Reply With Quote
Old 07-05-2011, 09:05 PM   #10
bbf2530
[quote author=Chris00gt link=topic=192480.msg4064487#msg4064487 date=1309908898]
Hi Chris. Hmmmmm...if that is the case, then a little reading of the Owners Manual by 2008 model year and later owners may provide more details and answer the question. I have a 2007 (no TPMS), and am feeling a bit lazy at the moment so have not taken the time to download the 2008 and later Manuals to read the TPMS section. However, those with 2008 and later model years may be able to solve this by reading their Owners Manual.
Hopefully someone will take the time to do so and report back to us as to whether the Owners Manual has any information concerning this subject?
