Removing Battery, Negative Terminal? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 01-09-2011, 10:18 PM   #1
dcolumbus
Bicycle Rider
Default Removing Battery, Negative Terminal?
Hey all!
I hope you can help me with this.
So what the frick? For some reason Ford decided to be "smart" and not allow for any mere human to replace their battery. I've been struggling with the negative battery terminal for far too long. I did a little research and apparently I need a battery terminal remover? Since when? I went into Pep Boys and they didn't even know what I was talking about.
How do I remove the negative battery terminal on my 2008 Fusion SEL6?
Thank you!
dcolumbus is offline   Reply With Quote
Old 01-09-2011, 10:30 PM   #2
HALOREALM
Le Mans: Prototype Class
HALOREALM's Avatar
Default Re: Removing Battery, Negative Terminal?
I just changed mine and all I used was a socket set. Got any pics of this?
I have a degree in Bovine Scatology
Etched Glass/ 32% Tint/Steeda CAI/Steeda Oil Cap/Engine Cover/Steeda resonator delete/Steeda Door Sills/Roush Lower Grill/Eibach Springs/
Magnaflow Mufflers/Sport Edition Wheels/Nexen CP662 Tires/DRT Rotors/ MGP Caliper Covers/ Flex Shift Knob/Embroidered Fusion Floor Mats/Smoked Markers/Ford safety & security package
HALOREALM is offline   Reply With Quote
Old 01-09-2011, 10:43 PM   #3
dcolumbus
Bicycle Rider
No pics. I wouldn't be able to take a picture of the issue anyway.
I loosen the negative terminal and it just slightly moves side to side. I can't pull up on it. There seems to be some kind of lip preventing it from sliding off... hence the terminal remover, I guess.
You have the exact same car I do?
Old 01-09-2011, 10:51 PM   #4
HALOREALM
HALOREALM's Avatar
06 SEL...can't imagine there is much different...??
Old 01-09-2011, 10:51 PM   #5
bbf2530
[quote author=dcolumbus link=topic=184621.msg3902698#msg3902698 date=1294625923]
Hey all!
Thank you!
Hi dcolumbus. Don't know if this will help solve your particular problem or not (also don't know why Pep Boys did not know what a "battery terminal remover" is), but here is what a battery terminal puller/remover looks like:
Old 01-09-2011, 11:04 PM   #6
acedeuce802
Moderator
I got mine off, try pulling harder?
I have no Fusion. I have a Miata.
I need a new sig.
acedeuce802 is offline   Reply With Quote
Old 01-09-2011, 11:05 PM   #7
dcolumbus
Bicycle Rider
Honestly no one knows that this problem is? I can't imagine that my car is somehow different than every other Fusion... this is ridiculous.
If I try and pry the terminal off at all, the metal (led or something) just bends. It's so frustrating. There's got to be a reason for this...
Old 01-09-2011, 11:09 PM   #8
HALOREALM
HALOREALM's Avatar
IDK...I just loosened the nut and pulled up. It was really not even hard to remove.
Old 01-10-2011, 11:18 AM   #9
biggee72
06 has a different battery than the 07+. On my 2007 the positive terminal was difficult to maneuver.
Old 01-10-2011, 11:37 AM   #10
blackfusion06
F1 Driver
I just loosened the nut stuck a flat headed screwdriver in the slot to open the clip and levered it off by putting the 8mm open ended wrench under the upper part and it came off easy. I really dont know why ford felt the need to make the cables so tight though? It was harder to put the cables back on. The negative was easy but the new battery was a little taller so the positive was hard to get on. I had to pop the clips like one of the other forum members posted to get the slack then couldnt get it back in though. (damn fat hands) That and I catapulted the little nut a few times trying to get the hold down bracket back on it. :shock:
