Where is my keyless entry code? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 11-21-2010, 05:45 PM   #1
danford1
Moped Rider
Default Where is my keyless entry code?
I just got a used 08 Fusion SEL V6 Sport with keyless entry. Where is the code kept?
The owners manual says on wallet card in glove box. This is a used car, no wallet card...
I know the codes are kept in another area of the car. Where is it?
Thanks.
Danford1
danford1 is offline   Reply With Quote
Old 11-21-2010, 05:54 PM   #2
mattrix
Grand Am Series
Default Re: Where is my keyless entry code?
From what I can tell you need a dealer to get the code for you. It doesn't look like you can do much without it.
mattrix is offline   Reply With Quote
Old 11-21-2010, 08:00 PM   #3
bbf2530
[quote author=danford1 link=topic=182622.msg3865281#msg3865281 date=1290375940]
Thanks.
Danford1
EDIT - Since I had my code/code card and did not feel like doing the necessary gymnastics to check the passenger compartment fuse box or passenger footwell areas for stickers, I had never really carefully checked before. For the heck of it I just did so and discovered that there is a sticker in my car. It is a white sticker located above the fuse box towards the interior fenderwall. Among other things (a barcode etc.), the keypad code is printed.
Hi Danford. As Mattrix stated, you will probably need to go to the Dealership to have them retrieve the Keyless Entry code. Bottom line is if you purchased the vehicle from a Ford Dealership, they should provide this code retrieval service for free. It is an integral part of the vehicle and it only takes about 5 minutes for them to hook up the vehicle to the Diagnostic system and retrieve the code.
However, if you did not purchase from a Ford Dealership, you can try this first: There has been anecdotal stories of people sometimes finding stickers with the code located in one of two spots. First, on a sticker located on or in the area of the PCM, which is located in the front passenger footwell, in the front right corner, up by the right side kick-panel and glovebox. Second, on a sticker located in/on/in the area of the passenger compartment fuse box, which is located below and to the left of the steering wheel, up under the dashboard.
Let us know how you make out.
Old 11-22-2010, 09:24 PM   #4
danford1
Moped Rider
I left a message with the dealer I got the car from.
Now I'll wait and see if they call back...
Thanks.
Danford1
Old 11-22-2010, 10:05 PM   #5
mattrix
Grand Am Series
Hopefully they do, if not bug them. It's something you need and should be easy for them to retrieve. Let us know how it turns out.
Old 11-23-2010, 04:22 PM   #6
bbf2530
Default Re: Where is my keyless entry code? NEW INFORMATION!
[size=12pt]Hi gang. Since I have my code/code card and did not feel like doing the necessary gymnastics to check the passenger compartment fuse box or passenger footwell areas for stickers in the past, I had never really carefully checked before. I'm just not as nimble as I used to be (plus, I am a bit lazier). :lmao:
You need to have your entire waist and lower body outside the car, with only your head and shoulders in the drivers side footwell, head up under the dashboard towards the brake pedal. To save yourself some grief, have a small flashlight with you.
Hope this information helps.
[/size]
PS - This will help save a few people some money on retrieval charges by the Dealership. However, it does not change the fact that when purchasing a used Fusion from a Ford/Lincoln-Mercury Dealership, they should provide the code as part of the purchase service.
Old 11-23-2010, 05:31 PM   #7
mattrix
Grand Am Series
We need pics of you in this position I think lol
Old 11-23-2010, 06:33 PM   #8
bbf2530
[quote author=Mattrix link=topic=182622.msg3867272#msg3867272 date=1290547887]
Hi Mattrix. Please, no Paparazzi!
Old 11-24-2010, 10:01 AM   #9
Daveninaz
Moped Rider
My 1997 Ford Explorer had keyless entry, the code was on a sticker on the inside of the jack area, Sounds like you found it but that's another place it could be.
1/03-4/09 - 1996 FORD EXPLORER passed away with 275,000 miles
4/09 - 7/10 - 2009 Fusion SE- Sandstone Traded in with 12,000 mls
07/10 - ALWAYS - 2010 Fusion SE with Mono-chrome and Tune
Daveninaz is offline   Reply With Quote
Old 11-30-2010, 08:03 PM   #10
danford1
Moped Rider
The dealer did call back. In fact they were very nice and apologized for not providing it at time of sale.
Slipped through the cracks as they say...
They said getting it is easy. The service dept can hook up to the car computer and have it very quick. No charge for this either if I go back to That dealer. If I go elsewhere, there would be a charge.
I'll get the code next time in in the dealers area.
Thanks.
PS I'll go peek under dash by fuse box anyway. If I find it I'll post back.
Danford1
