Synthetic vs Conventional Oil - FordFusionClub.com : The #1 Ford Fusion Forum
Old 10-15-2010, 10:18 AM   #1
blackfusion07
F1 Driver
blackfusion07's Avatar
Default Synthetic vs Conventional Oil
Hopefully this doesn't spark too much of a debate, I'm just looking for a couple quick answers.
I'm a couple hundred miles over my suggested 3000 mile oil change. A roommate suggested I switch over to synthetic (gave me the oil run down) and pretty much convinced me to do so. Now this morning a friend of mine said switching to synthetic for the first time at 78k miles could cause issues, such as leaks.
Does anyone see a problem with me switching over? I'd like to due to the benefits, but if there are leaks, seals or any gasket issues I would assume to stick with conventional.
blackfusion07 is offline   Reply With Quote
Old 10-15-2010, 10:25 AM   #2
fatabbot
fatabbot's Avatar
Default Re: Synthetic vs Conventional Oil
It shouldn't cause any issues.
I have no problem with synthetic oils, but I will warn you to not listen to some of the hype. An engine changed with conventional oil at reasonable intervals will last just as long.
When I change my own oil, which is becoming increasingly rare as I get free maintenance on my car, I use NAPA brand full synthetic. Half the price of the overhyped oils and gets just as good of UOAs.
fatabbot is offline   Reply With Quote
Old 10-15-2010, 10:30 AM   #3
bbf2530
[quote author=BlackFusion07 link=topic=180920.msg3828946#msg3828946 date=1287152296]
Edit - When I began typing my reply, fatabbot had not yet posted yet. Curse my slow fingers!
:lmao:
Hi BlackFusion. There is no reason that you can not switch over to a full synthetic with your mileage, if you wish.
Also, just as an FYI: I believe that the "Normal Service" oil change interval for the 2007 Fusion (I-4 and V-6) is 6 months/5,000 miles. "Severe Duty" or "Severe Service" would be 6 months/3,000 miles EDIT-3 months/3,000 miles. But don't take my word for it, you can find the correct information in the Scheduled Maintenance Guide. My apologies if you already knew the "Recommended OCI" information. And of course, if you wish to change earlier than Ford recommends, it will certainly not hurt anything.
Hope this information helps.
Old 10-15-2010, 12:02 PM   #4
blackfusion07
F1 Driver
Thanks for the info fellas. I figured synthetic wouldn't cause any issues but I'd rather ask before I do.
Old 10-25-2010, 08:17 PM   #5
Curmudgeon
Short Track Racer
BlackFusion...just curious...what oil are you currently using, i.e. at the time of your initial inquiry?
Curmudgeon is offline   Reply With Quote
Old 10-25-2010, 08:27 PM   #6
blackfusion07
F1 Driver
I'm not exactly sure what was in it previously. I ended up going with Valvoline this time around...
Old 10-25-2010, 09:40 PM   #7
HALOREALM
Le Mans: Prototype Class
HALOREALM's Avatar
I just stayed with the Motorcraft semi-syn @ 5000. I am amazed how clean the stuff looks at oil change.
I have a degree in Bovine Scatology
Etched Glass/ 32% Tint/Steeda CAI/Steeda Oil Cap/Engine Cover/Steeda resonator delete/Steeda Door Sills/Roush Lower Grill/Eibach Springs/
Magnaflow Mufflers/Sport Edition Wheels/Nexen CP662 Tires/DRT Rotors/ MGP Caliper Covers/ Flex Shift Knob/Embroidered Fusion Floor Mats/Smoked Markers/Ford safety & security package
HALOREALM is offline   Reply With Quote
Old 10-25-2010, 10:23 PM   #8
Curmudgeon
Short Track Racer
[quote author=HALOREALM link=topic=180920.msg3839852#msg3839852 date=1288057229]
We won't know until the GF-5/SN Motorcraft 5W20 semi-syn specs are available, but I suspect that oil's characteristics will be equivalent to some GF-4 'synthetics' (the distinction between conventional, semi-syn, and syn is getting nearly indistinguishable). With UOA TBNs of circa 3.4 (1/2 of virgin) at 5,000 miles, I'm convinced that my regimen of using Motorcraft semi-syn and DIY changes at 5,000 miles/6 months is cost effective and provides optimal engine care under my driving conditions and mild climate.
The last oil change I did on my 2nd vehicle (2004 5.4 F-150) was with Pennzoil 5W20 'conventional' (can any of the GF-5 oils be labeled [b]conventional[b] any more). The new PYB meets/exceeds GF-5 and Ford's 930 specs.
