Amplifier Wiring - FordFusionClub.com : The #1 Ford Fusion Forum
Old 10-12-2010, 07:04 PM   #1
belizeandevil
Grand Am Series
Send a message via MSN to belizeandevil
Default Amplifier Wiring
Just needed to find out something here. I am wondering which gauge power and ground wire is better to run for my system. Total rms will be around 1300 rms.
belizeandevil is offline   Reply With Quote
Old 10-12-2010, 07:11 PM   #2
sinthcity
Short Track Racer
Default Re: Amplifier Wiring
[quote author=belizeandevil link=topic=180795.msg3825918#msg3825918 date=1286924647]
4ga or bigger, 2ga is your best bet.
Don't forget to re-ground your battery, as the stock body to battery cable is smaller than this.
More info:
Gauge Current Capacity (amps)
1/0 350
2 225
4 150
8 100
10 60
12 40
14 25
16 15
now: billet grille | magnaflow catback | sts | street unit dogbone | stb | 6000 k hids | smoked markers | 20% tint | jvc head | infinity components, speaks, subs, amp
soon: rims | springs | rsb | steeda endlinks | h-brace
wishlist: fusionturbos.com turbo kit!!! | coilovers
sinthcity is offline   Reply With Quote
Old 10-12-2010, 10:10 PM   #3
platinumsc7
Grand Am Series
I ran 1/0 wire. I was running 2000 rms and I figured I wanted as much current as I could get, and the price was right. My plan was to run a 1/0 ground to a distribution block also. Of course my amps took a shit after 6-7 years of hard work so I've got a little 600 watt JBL in there now. Not quite the same.
platinumsc7 is offline   Reply With Quote
Old 10-13-2010, 12:05 AM   #4
Canadian_LX
Senior Member
1/0 gauge for sure.
Might want to consider upgrade all three of your engine wires - not just the battery ground. This means you should run *at least* 4ga. wire (i used 1/0) from your alternator to battery positive, your engine to ground, and your ground to battery negative.
This should defeat any voltage drops which will cause dimming of lights and will help keep your amp from going into protect mode if you are running it at a lower impedance (1ohm).
As a side note to the chart posted above, the issue with the numbers stated is that not all audio cable is manufactured using the same materials so not all wires (though the same size) will carry the same current. For an example, i am using KnuKonceptz 1/0 KLMX cable which has a current capacity of 250 amps. They have a FLEX cable which is the same size but 3x the price that has a current capacity of 350 amps.
With your amp putting out only 1300w you should be fine with any 1/0 wire though.
Old 10-13-2010, 02:00 AM   #5
belizeandevil
Grand Am Series
Thanks for the quick replies guys. KnuKonceptz wiring i was looking to order. So i guess 1/0 gauge is the best way to go then.
Old 10-13-2010, 11:05 AM   #6
seasonalskier
Senior Member
seasonalskier's Avatar
[quote author=Canadian_LX link=topic=180795.msg3826212#msg3826212 date=1286942731]
I would highly recommend this too.
Old 10-13-2010, 11:54 PM   #7
belizeandevil
Grand Am Series
So if i use 4 gauge wiring, that would be ok since the amps accepts up to 4 gauge wiring. then upgrade everything with 4 gauge.
Old 10-14-2010, 01:01 AM   #8
sinthcity
Short Track Racer
[quote author=belizeandevil link=topic=180795.msg3827478#msg3827478 date=1287028447]
Only one amp? Then yep, use the size the amp allows.
Otherwise, run a 1/0 to a distribution block then 4ga from that to muliple amps
Old 10-14-2010, 06:11 AM   #9
Canadian_LX
Senior Member
What amp is this? 1300w and only 4 gauge wiring doesn't sound right.
Old 10-14-2010, 02:02 PM   #10
sinthcity
Short Track Racer
[quote author=Canadian_LX link=topic=180795.msg3827572#msg3827572 date=1287051085]
1300w is 120 amps max (at 11-18 volts). 4 gauge is certified for 150 amps.
  FordFusionClub.com : The #1 Ford Fusion Forum > Ford Fusion Visual / Audio > Electronics Discussion
