Coolant Flush? - FordFusionClub.com : The #1 Ford Fusion Forum
Old 09-10-2010, 06:52 PM   #1
fhartell@yahoo.com
Short Track Racer
Default Coolant Flush?
I have an '08 w/ 52+K on od. When should coolant be changed? Is there a way of draining it all? Thanks
'08 SEL V6 w/ SAP,Steeda CAI,Steeda TBS,Magnaflow Exhaust,SCT X3 Tuner,CD3 Strut Tower Brace,Extreme 4300k HID Conversion,Red/Black CF Dash Kit,A Bunch of LED's, EBC Red Stuff Pads, EBC Slotted/Dimpled Rotors & Yokohama AVID ENVigor 225/45 18 Tires
fhartell@yahoo.com is offline   Reply With Quote
Old 09-10-2010, 08:34 PM   #2
biggee72
Default Re: Coolant Flush?
I did mine @ 30k. Always a good idea to get it done. I'll tell ya..it took like an hour to drain. It came out slowwwwwwww..might be better to have a shop do it if possible.
Old 09-11-2010, 09:43 PM   #3
cos
Le Mans: GT Class
I prefer "drain 'n fills" every 2 yrs - easiest, fastest and the most economical way to maintain the cooling system.
I use a 50/50 mix of distilled water and Xerex G-05. Also don't forget to remove your coolant tank's cap before you open the drain valve so the coolant flows out quickly and also remember to open the burp valve when your done, the location of which is shown in your owner's manual - leave it open for at least a minute to let the trapped air out. Hope this helps.
'06 Fusion - Black, 2.3/5 speed manual
SCT X3 (Steeda 93 tune)
cos is offline   Reply With Quote
Old 09-14-2010, 02:47 PM   #4
morgan2112
Moped Rider
[quote author=cos link=topic=179351.msg3794085#msg3794085 date=1284255837]
Do you need a special tool or key to open the burp valve? Mine 2008 SE looks like a key-hole? How about a nice Do-It-Yourself walkthrough?? Do these exist anywhere for our beloved FUSION 3.0???
morgan2112 is offline   Reply With Quote
Old 10-12-2010, 11:43 PM   #5
morgan2112
Moped Rider
Hey Guys. How about a nice Do-It-Yourself walkthrough?? Do these exist anywhere for our beloved FUSION 3.0??? How do I burp the cooling system correctly and will 2 gallons be enough of 50/50 premix antifreez be enough for my Texas climate? Do you just use a flathead on the burp valve? Thanks for the help!
Old 10-23-2010, 06:54 PM   #6
zburns
Short Track Racer
I would love to know this too, since my car just tripped 45k.
-Z
07 SEL V6. Body Color Painted Grille / Painted Rear Bumper Valence / Clear Side Markers / HD Lip / Throttle Body Grounding Wire mod / K&N Typhoon Air Intake / Steeda Strut Bar / 35% on sides / 20% back / Steeda springs / Tokico shocks/struts / 5000k HIDs / 25mm spacers
zburns is offline   Reply With Quote
Old 11-09-2010, 05:14 PM   #7
yeloxr7
Grand Am Series
My owners manual says the coolant doesn't need to be changed until 100,000 miles.......
2011 Fusion SE I4 6-speed Auto Silver with Appearance Package.
1969 Mercury Cougar XR7 351W
My other 1200 cars are 1/25 scale.......
yeloxr7 is offline   Reply With Quote
Old 12-31-2010, 12:33 PM   #8
sliverfusion08
Grand Am Series
anyone ever get an answer to this? need to do mine next week, 3years old and 30k. also is the little red cap/plug on the drivers side the one you use to open to do this? i have an 08 se 2.3L ? thanks
sliverfusion08 is offline   Reply With Quote
Old 01-08-2011, 08:21 PM   #9
sliverfusion08
Grand Am Series
well did the flush today and now i have what sounds like water slushing/cavitating around? opened the bleed valve and poured slowly till it showed full range cold, also till it flowed out of the bleed valve top. drove around 15mins both vent set to cool and heat a/c on to make sure it circulated the fluids, temp gauge reads fine just an abnormal noise and is making the wife a little uneasy. any input is appreciated. thanks
Old 01-11-2011, 06:06 PM   #10
sliverfusion08
Grand Am Series
never mind, got it solved....
