Where is the Fuse Box Located . . . - FordFusionClub.com : The #1 Ford Fusion Forum
Old 07-03-2010, 02:47 PM   #1
texasmuser
Moped Rider
Default Where is the Fuse Box Located . . .
. . . on the '07 Mercury Milan? I think fuse F15 (to the Cigar Lighter) is blown and I'd like to replace it if it is. Is this, as I assume, the only "power piont" this car has? Thanks, in advance!
texasmuser is offline   Reply With Quote
Old 07-03-2010, 03:14 PM   #2
blackfusion07
F1 Driver
blackfusion07's Avatar
Default Re: Where is the Fuse Box Located . . .
This may prove to be worthless...
In the Fusion the fuse box is located above the airbox (right side of the engine in a black box).
blackfusion07 is offline   Reply With Quote
Old 07-03-2010, 03:32 PM   #3
texasmuser
Moped Rider
"This may prove to be worthless...
In the Fusion the fuse box is located above the airbox (right side of the engine in a black box)."
If that's where it is, then GREAT! I ask because (1) the dealership I went to wouldnt even take the time to tell or show me, (2) I got the impression (from where, I dont know) the black box you're referring to is some kind of a power distribution center, and not a simple fuse box, and (3) I'm used to the old or pick-up truck location of kinda under the dashboard near the driver's left foot.
I'll check it out!
Old 07-03-2010, 03:48 PM   #4
blackfusion07
F1 Driver
[quote author=texasmuser link=topic=175658.msg3716550#msg3716550 date=1278181923]
I'll check it out!
For me that's where all the fuses are located so that's why I'm thinking it should be in the same location for the Milan.
Old 07-03-2010, 04:53 PM   #5
bbf2530
[quote author=texasmuser link=topic=175658.msg3716534#msg3716534 date=1278179256]
Hi texas. There are two fuse boxes, one in the passenger compartment, on the drivers side, under the dash to the left of the steering wheel ("near the drivers left foot&quot. The other is in the engine compartment. There are diagrams and charts in the Owners Manual outlining the approximate locations and fuse numbers.
Hope this information helps.
Old 07-03-2010, 04:54 PM   #6
blackfusion07
F1 Driver
At least I was half right
Old 07-03-2010, 06:22 PM   #7
texasmuser
Moped Rider
"Hi texas. There are two fuse boxes, one in the passenger compartment, on the drivers side, under the dash to the left of the steering wheel ("near the drivers left foot&quot. The other is in the engine compartment. There are diagrams and charts in the Owners Manual outlining the approximate locations and fuse numbers.
Good luck."
I figured as such. I bought the car used and it didnt come with the Owners Manual . . .
Old 07-03-2010, 08:26 PM   #8
texasmuser
Moped Rider
I found the fuse box tucked up under the dash. Found the fried fuse, replaced it, and the auxillary power point (right behind - or in front of - the shift) now works!
Old 07-03-2010, 10:01 PM   #9
bbf2530
[quote author=texasmuser link=topic=175658.msg3716645#msg3716645 date=1278192149]
Hi texas. You can download a PDF version of your Owners Manual here: www.fleet.ford.com/maintenance/owners_manuals/default.asp
Fill in the drop-downs and click "Submit". Then click "Owners Guide". As you will see, you can also download PDF versions of other Guides for your car.
The PDF versions come in very handy. I actually use them more than the hard copies.
Old 07-06-2010, 12:04 PM   #10
rpreuss
Bicycle Rider
[quote author=bbf2530 link=topic=175658.msg3716766#msg3716766 date=1278205297]
And it is search-able - a great "tool" for finding what's hidden in the manual.
2010 FFH 502A Silver Metallic
[img width=199 height=100]http://preussweb.com/My FFH p.jpg[/img]
rpreuss is offline   Reply With Quote
