How to: Springs and shock install (lots of pics) - Page 4 - FordFusionClub.com : The #1 Ford Fusion Forum
Old 03-01-2011, 11:06 AM   #31
acedeuce802
Moderator
Default Re: How to: Springs and shock install (lots of pics)
[quote author=Barchetta link=topic=171914.msg3948066#msg3948066 date=1298945312]
I've always been afraid to use a floor jack directly on that lip area the manual shows, so I cut a piece of treated 2x4, and cross-grain sawed out an area for the lip to sit into. I've changed a couple of sets of tires like this; so far so good, although the wood does creak sometimes. :shock:
So you jack up both sides of the front on this lip with 2 floor jacks, no problem?
I need to make one of those!
I have no Fusion. I have a Miata.
I need a new sig.
acedeuce802 is offline   Reply With Quote
Old 03-13-2011, 07:33 PM   #32
seasonalskier
Senior Member
seasonalskier's Avatar
Dude, words can not describe how thankful I am you wrote this up. It helps mechanical morons like me learn better before I destroy a few parts. I will for sure have this open next week when I finally swap out my suspension. But again thanks a million for doing this :P
Old 03-13-2011, 08:31 PM   #33
Ceace
Le Mans: Prototype Class
Send a message via Yahoo to Ceace
[quote author=Seasonalskier link=topic=171914.msg3961752#msg3961752 date=1300059197]
+2 He deserves a DIY Write-Up of the Year Award!!!
Blinking and Clear Side Markers, Debadged, 35% Tint, 18" Alloy Rims Wrapped in 245/40/18 Tires, Lip Spoiler, OEM Fog Lights, Intake Silencer Delete, Upgraded radio bezel with clock, double din touch DVD stereo, LED's, custom exhaust valance, dual exhaust upgrade, HD front lip
Ceace is offline   Reply With Quote
Old 03-14-2011, 01:13 AM   #34
20louie06
20louie06's Avatar
Send a message via AIM to 20louie06
Thanks for the kind words guys. I'm happy to help out anyway I can.
If everything is under control, you're not going fast enough.
My Mod Thread
20louie06 is offline   Reply With Quote
Old 04-05-2011, 12:54 AM   #35
gunzburg
Moped Rider
Hi everyone, new here. I found the site looking for springs for my 2010 Fusion Sport. I must say I love this car but have to get rid of some of the gap. I decided on the Eibach 1.6" pro springs.
This write is perfect, it will make the job alot easier. I just have a couple questions.
What are the torque specs for everything? I can't seem to find it anywhere. And where anybody's alignments off, if so do I need eccentric bolts or is the car pretty adjustable from the factory?
Thanks again for everything, this is a great forum.
gunzburg is offline   Reply With Quote
Old 04-05-2011, 08:56 AM   #36
acedeuce802
Moderator
Not sure about torque specs, I just tightened them pretty darn tight with a 1/2 in. drive. You will not need further camber adjustment. The rear's are adjustable from the factory, and the front's aren't affected much since we have double wishbone's in the front.
I need a new sig.
Old 04-05-2011, 09:50 AM   #37
seasonalskier
Senior Member
Torque specs are like Adam said, Tight.
The fronts are only adjustable with a set of adjustable ball joints, I just sent mine in for an alignment after a drop and its only at a -1.1 degree camber in the front so not at all bad and my Teins dropped the car by about 2" so your 1.6" will keep it even closer in alignment anyways.
Old 04-05-2011, 10:21 AM   #38
Mercury_66Comet_07Milan
Mercury_66Comet_07Milan's Avatar
Front Suspension
Rear Suspension
These specs were for a 2007 Mercury Milan. Not sure if they apply to the 2010's.
New Mercury-Old Mercury
I admire your Ford, but you're jealous of my Mercury.
Mercury_66Comet_07Milan is offline   Reply With Quote
Old 04-05-2011, 11:51 PM   #39
gunzburg
Moped Rider
Thank you for that that is exactly what I needed to find.
Old 04-16-2011, 11:01 PM   #40
gunzburg
Moped Rider
Just wanted to say thanks to everyone here. Installed the springs on Wednesday, went smooth. Man the spring compressor business is a butt kicker, I was worn out just from that. Guess as I was doing it every muscle in my body was tense and my nerves were shot but it was easy and I enjoyed it.
The car sits perfectly now, the way it should look and the ride is great.
Thanks again.
