Thread Tools |
#1 |
Moped Rider
I am a Ford master tech and we were sent communications from Ford that they are preparing to void warranties or place warranty restrictions on ANY ecoboost equipped vehicles(Fusion/Milan)that have been altered for performance reasons. If you alter these vehicles your treading on dangerous ground, be smart and wait until the warranty is run out or understand that your likely to lose your coverage. Here is the exact letter sent to ALL Ford dealers:
To: All Ford and Lincoln Mercury Dealerships Subject: Aftermarket Modifications – Warranty Cancellation BACKGROUND Aftermarket companies (referred to as "tuners" attempt to increase an engine's torque and power output beyond the design limits which may cause powertrain failures. This is often accomplished by modifying the engine calibration (referred to as "chipping" but may also include modifications or adjustments to other components. Per the Warranty Guide that is provided to the customer and the Warranty & Policy Manual, failures resulting from modifications are not warranted by Ford Motor Company.All powertrains are subject to warranty cancellation if a modification causes a failure. For the 3.5L EcoBoost technical service bulletin TSB 10-2-6 was published to enable your technicians to determine: If a powertrain failure resulted from an unauthorized modification If the engine, transmission, or entire powertrain warranty should be cancelled Per the inspection process included in this TSB a Ford Motor Company inspector may assist with this analysis. When the inspection process clearly indicates that a failure was caused by an unauthorized modification/alteration the repair should not be completed under Warranty and, using the following process, the vehicle's remaining Engine, Transmission, or Powertrain warranty should be cancelled. WARRANTY CANCELLATION PROCESS To initiate a warranty cancellation on an affected vehicle, submit a warranty cancellation request form through FMCDealer.com. This on-line form can be accessed as follows: FMCDealer.com Select Parts & Service tab Select Warranty Administration & Parts Return Select Warranty Cancellation / Reinstatement Request Form Complete and submit this form on-line. Once the warranty is cancelled an OASIS message will advise all dealerships that the vehicle is no longer eligible for warranty coverage. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Short Track Racer
[quote author=hgffrank link=topic=167126.msg3543883#msg3543883 date=1265980207]
I am a Ford master tech and we were sent communications from Ford that they are preparing to void warranties or place warranty restrictions on ANY ecoboost equipped vehicles(Fusion/Milan)that have been altered for performance reasons. If you alter these vehicles your treading on dangerous ground, be smart and wait until the warranty is run out or understand that your likely to lose your coverage. Here is the exact letter sent to ALL Ford dealers: To: All Ford and Lincoln Mercury Dealerships Subject: Aftermarket Modifications – Warranty Cancellation BACKGROUND Aftermarket companies (referred to as "tuners" attempt to increase an engine's torque and power output beyond the design limits which may cause powertrain failures. This is often accomplished by modifying the engine calibration (referred to as "chipping" but may also include modifications or adjustments to other components. Per the Warranty Guide that is provided to the customer and the Warranty & Policy Manual, failures resulting from modifications are not warranted by Ford Motor Company.All powertrains are subject to warranty cancellation if a modification causes a failure. For the 3.5L EcoBoost technical service bulletin TSB 10-2-6 was published to enable your technicians to determine: If a powertrain failure resulted from an unauthorized modification If the engine, transmission, or entire powertrain warranty should be cancelled Per the inspection process included in this TSB a Ford Motor Company inspector may assist with this analysis. When the inspection process clearly indicates that a failure was caused by an unauthorized modification/alteration the repair should not be completed under Warranty and, using the following process, the vehicle's remaining Engine, Transmission, or Powertrain warranty should be cancelled. WARRANTY CANCELLATION PROCESS To initiate a warranty cancellation on an affected vehicle, submit a warranty cancellation request form through FMCDealer.com. This on-line form can be accessed as follows: FMCDealer.com Select Parts & Service tab Select Warranty Administration & Parts Return Select Warranty Cancellation / Reinstatement Request Form Complete and submit this form on-line. Once the warranty is cancelled an OASIS message will advise all dealerships that the vehicle is no longer eligible for warranty coverage. [/quote] Do you know how many (approx) warranties are canceled as a result of modifications? |
#3 |
Moped Rider
no I dont, sorry but I think its still a bit early yet to get a take on the numbers. These engines have only been out for a year or so. Usually takes a year or two before modified vehicles start turning up, however the attitude that Ford is taking leads me to believe they are already seeing cars coming in with mods, and are taking action agaist warranties. I would imagine if someone really wanted to know they could file a FOIA request with Ford for the information and they would have to disclose it. Interesting thing is; the tsb they refer us tech to in order to aid in determination actually lays out the groundwork for someone who would want to mod these engines.
Makes me want to get a Fusion with ecoboost just to dabble with since I'm a tech and could cover up pretty much anything I want. I would guess that with proper mods and tricks these engines could easily hit the 450hp mark with an absolutely flat torque curve |
#4 |
Le Mans: GT Class
We don't have ecoboost engines...
And hasn't this always been the case? Most people just know to return their tune to stock before going to the dealer. |
#5 |
Grand Am Series
Yeah no ecoboost in the fusion.. and if there is, I'm bringing my car back and getting one with it.. however, changing the tune then changing it back, or just waiting for the warranty is out.. Manufacturers have always voided warranties for mods..
Owner: www.AmericanMustangs.net |
#6 |
Moped Rider
I'm thinking it will be in fusion/milan, so far Taurus/flex/MK that I know of
#7 |
It'll be in the fusion SUPPOSEDLY by 2013 or so. But yeah, isn't this always the case? If Ford is making a bigger deal out of it than other engines than that just tells me that they are at the HP limits as it is for the whole drivetrain which isn't a good thing.
#8 |
Le Mans: GT Class
I agree with all of the above.
When i seen the beware i thought the tranny's was falling out of a 2.5 again or or the 3.5 was going to self destruct. ( all was missleading) Can you please tell use some good things that is going on with ford please. No disrespect just my humer. |
#9 |
Go-Kart Driver
[quote author=speedfreak87 link=topic=167126.msg3544163#msg3544163 date=1265994416]
Yeah no ecoboost in the fusion.. and if there is, I'm bringing my car back and getting one with it.. however, changing the tune then changing it back, or just waiting for the warranty is out.. Manufacturers have always voided warranties for mods.. [/quote] Yes, however, on most vehicles, Ford isn't very serious on policing the mods. If you chip your 3.5L Fusion and remove it before service, I'd be very supprised if anyone ever even tried to catch it. Because your chip isn't pushing the envelope much. However, with a Power Stroke or an EcoBoost, a chip can add BIG power because you can turn up the boost and increase fuel. There's already a video of a SHO on youtube run the 1/4 in the 12's with only a tune. However, I have a feeling the driveline may have issues with this extra power. Also on the Diesels we've seen headgasket (and headbolt) failures due to the extra pressure caused by chips. Thats the reason I expect Ford will be policeing mods heavily on the turbo engines.
2006 Fusion SEL V6, Steeda CAI, Magnaflow exhaust, Steeda throttle body spacer, Steeda tune, Steeda strut tower brace, Steeda rear sway bar, Eibach springs, DBA rotors, Hawk pads, Boss wheels. |
#10 |
Moped Rider
Ford is going to begin policing more, and yes there are good things going on with Ford. We have the 2011 6.7L Diesel coming out that is a massive improvement, its a monster not to mention its supposedly going to get 20+ mpg which is better than many v8 gas engines, imagine turning your valve cover into an intake manifold, dumping your exhaust into the valley directly into a single turbine which spins twin impellers...these things alone tell you that Ford is attacking the market with revolutionary design changes, not to mention they have taken the most common parts that fail and slapped then right on top for easy service.
Forgive me for thinking of the ecoboost in Fusion/milans already, I work on Diesel trucks/vans so I dont experience the car side very much other than the occasional new car prep which is always fun, those new Tuarus SHO's are a blast, although I cant stand the rediculously designed paddle shifters that just dont function in a natural manner, you would expect the left to shift down and right to shift up but they made both paddles shift both ways to try and please most people, without being used to the setup I couldnt paddle shift in manual very well, not to mention I think the times are better leaving it in manual therefore the only use of paddles would be engine braking on hills and such. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
