Fuel tank wont fill all the way - FordFusionClub.com : The #1 Ford Fusion Forum
Old 12-31-2009, 12:35 PM   #1
acedeuce802
Moderator
Default Fuel tank wont fill all the way
2 of the last 3 times I have filled up with gas, I can only fill the tank up about half way, and the gas is cut off. Is anyone else having this problem? I searched around and haven't found anything with the Fusions.
I have no Fusion. I have a Miata.
I need a new sig.
acedeuce802 is offline   Reply With Quote
Old 12-31-2009, 01:20 PM   #2
blackfusion06
F1 Driver
Default Re: Fuel tank wont fill all the way
[quote author=acedeuce802 link=topic=163962.msg3477364#msg3477364 date=1262277341]
ok sounds stupid but I had a problem with the car kicking off the pump a bunch of times at the gas station. The attendant said leave the car running and it worked. dunno why but worth a try.
Old 12-31-2009, 01:23 PM   #3
TheUkrainian
F1 Driver
Send a message via AIM to TheUkrainian Send a message via MSN to TheUkrainian
I've had this happen to me twice, both times at the same gas station too. Maybe it's the pump?
Cleverly disguised as a responsible college student...
TheUkrainian is offline   Reply With Quote
Old 12-31-2009, 03:07 PM   #4
acedeuce802
Moderator
[quote author=blackfusion06 link=topic=163962.msg3477398#msg3477398 date=1262280000]
Is that safe? lol, ill have to try that.
[quote author=TheUkrainian link=topic=163962.msg3477402#msg3477402 date=1262280222]
It could be, the first time it happened, it looked like an older pump, so after that I used the ones that looked like newer pumps, and still happened, but they were both at the same station.
I need a new sig.
Old 12-31-2009, 03:41 PM   #5
TheUkrainian
F1 Driver
The one station that it happened to me at is on my way to school so I don't really stop at it unless I forget to get gas and am running low (it's 1 of 3 truck stops along I-94 that usually have lower priced gas) and the pumps did look a little old.
Old 01-05-2010, 09:10 PM   #6
Black Phantom
Bicycle Rider
Send a message via MSN to Black Phantom Send a message via Yahoo to Black Phantom
I had a 2007 Ford Mustang which I traded for a 2010 Sel Fusion this December on account of said problem"gas fill up problem" TSB Ford Bulletin 07-21-12. This problem has been happening since 2005 without any solution. Hopefully this is not the same problem on my new Fusion! If so I might have to stop bying Ford products,only bought 12 so far!
Black Phantom is offline   Reply With Quote
Old 01-05-2010, 11:44 PM   #7
doug48843
Le Mans: GT Class
Send a message via AIM to doug48843
I can't say I've had problems with the pump clicking off when it's only 1/2 full, but I have felt that once the pump clicks off, that's all she wrote. Seldom can get any more fuel into the tank. I know everyone preaches not to continue to pump, but the OCD person inside me insists on trying to "round up" my purchases to an even amount.
I wouldn't however recommended filling the car up with it running. Can potentially create some issues with the emission systems and throw a CEL. This is besides the general safety factor, of course.
APR Stage 2 + and assorted other crap
doug48843 is offline   Reply With Quote
Old 01-05-2010, 11:56 PM   #8
acedeuce802
Moderator
Thanks for the input Doug!! My last fill up went fine, filled right up, this was at the same station, but different pump, i realized that the two times it has not filled up was at a pump with 3 hoses, whereas when it fills all the way up, there is 1 hose with 3 octane buttons.
I need a new sig.
Old 01-06-2010, 12:01 AM   #9
doug48843
Le Mans: GT Class
Some of the problem may indeed be the station and their pumps. Simply might be more "sensitive" than others. I typically get gas at only 3 stations (convenient to work, home and on the way home) and I haven't had any real issues at any of them.
Old 02-03-2010, 01:24 PM   #10
Emark182
Bicycle Rider
I just bought an 06 Fusion last weekend. I had this problem as well. I went to fill up the tank, and the pump stopped so I assumed it was full. When i started the car, the gauge only read 3/4 full. I hope it is not a "extreme" problem.
Emark182 is offline   Reply With Quote
